Integra GS-R
Old Nov 1, 2003 | 09:46 AM
  #51
DVPGSR's Avatar
DVPGSR
I need sleep...
Originally posted by infamous1se619
The vtec motor wasnt made for all out power. it was made for streetablity. You can make a non vtec motor rev as high as a vtec one. the only consequence is a shitty idle.
If the VTEC motors were not meant for power why is that technology used in their race cars? Why do the Type-R's only come with VTEC engines? How come the NSX does not have a non-VTEC engine available?
Also you can make a non-VTEC motor rev as high as a VTEC motor but you are setting yourself up for one thing....a motor that goes BOOM!
Old Nov 1, 2003 | 10:10 AM
  #52
91Teg's Avatar
91Teg
Originally posted by Azinracer
ok here's my car and engine mods, i'm talking about turbo'in this set up not, choosing ls/vtec over ls turbo or gsr. i'm strictly talking about turboin an ls/vtec car properly, it will most likely hit the 12's
mods:
98' B18B block
balanced bottom end
shotpeened LS rods w/ARP rod bolts
.25 over Civic Type R pistons and rings
ported and polished head from JDM B16A
Webb valve springs w/tianium retainers
USDM Type R intake manifold and cams
JDM Type R throttlebody
RC 310cc injectors
DC 4-2-1 stainless headers
AEM CAI
AEM adjustable cam gears
AEM Fuel Pressure regulator
AEM Fuel Rail
MSD 6A,Blaster SS coil
SPOON oil cap
SPOON radiator cap
Hondata ECU
Greddy MX exhaust
JDM YS-1 trans.w/Quaife LSD
Clutchmasters stage 3 clutch and 9lb.flywheel
Tokico 5 way adjustable struts
Neuspeed race springs
ingalls front/rear camber kit
Energy Suspension bushing kit
S/T F/R sway bars
SPOON front and rear strut bars
Skunk 2 lower tie bar
Power Stop drilled/slotted disc's w/russell steel braided brake lines
House of Kolor candy purple
JDM 1 pc. Headlights
Fiber Images CF hood
JDM gauge cluster
Autometer gauges
JDM back seat w/headrests
SONY MEX-5DI deck
Sony 4/3/2 300watt amp
Sony 2/1 250watt amp
Polk Audio front and rear components
JL Audio(2)10in w3 subs
Clifford inteleguard 8000
http://www.imagestation.com/album/?id=4289792219
Incredible car man.
Old Nov 1, 2003 | 01:12 PM
  #53
infamous1se619's Avatar
infamous1se619
stock for stock a vtec engine is superior to a non vtec. but wen u get into full time racing, its a whole different ballgame. Im not saying a vtec engine cannot be a beast. This is for you nonvtec haters.
Theres always a different preference for each person. most people(obviously) like the vtec engine but some other people(the few) will choose a diffent method of attack. More torque and power rather than high reving.
No a nonvtec motor reving as high as a gsr motor will not go "boom" thats y we invented something called "tuning"
Old Nov 1, 2003 | 04:20 PM
  #54
DVPGSR's Avatar
DVPGSR
I need sleep...
Even with tuning you are still risking the motor. There is a reason that the VTEC motors have oil squirters below the piston...part of which allows the motors to rev so high. With out this the long term stability of the engine is compromised, unless you rebuild the internals every so often.
Old Nov 1, 2003 | 05:26 PM
  #55
infamous1se619
I do agree oil squirters do provide the blocks strength over a long period of time in terms of NA. but There are reliable aftermarket solutions to reinforce higher reving on nonvtec motors such as a girdle to protect the main caps against the severe sideloads the lower rod ratio blocks generate as you rev into the higher rpms which the more aggressive vtec cam lobe specs demand. Also with forged rods and pistons and rod bolts you can rev even farther then a gsr can.
Old Nov 4, 2003 | 10:24 AM
  #56
BonzoAPD's Avatar
BonzoAPD
Originally posted by Snoopy
my bike > alL yu0z that are bitchin and moanin :loco: :joshers:
yes snoopy's bike is the shiznit :fawk:
Old Nov 4, 2003 | 10:28 AM
  #57
DVPGSR's Avatar
DVPGSR
I need sleep...
After spending how much $$ though? Add the same or similar mods to a GSR engine and it will still be a better motor.
Old Nov 4, 2003 | 10:54 AM
  #58
Dintegra97's Avatar
Dintegra97
i have the very base model integra. Its an rs. no sunroof, ac, abs. i love it tho. i beat 5th gen preludes from a dead stop. From a rolling start its a different story but thats when i hit the nitrous and im gone. My model is the lightest model. its lighter than the type r which with the low end torque from the ls motor makes it a quick little car in the quarter. I would rather have mine than a gsr. Bc i can put a better engine in and be a lot lighter than other integras. Anyways, i never look down on a base integra bc i know they can be fast.
Old Nov 4, 2003 | 10:56 AM
  #59
Dintegra97's Avatar
Dintegra97
Dont get me wrong. Vtec is nice and so are gsr's but base models can hold their own too.
Old Nov 4, 2003 | 11:26 AM
  #60
ggrrssyydik's Avatar
ggrrssyydik
if you know how to drop a motor go find a RS that has no motor or that the motor is no good, and drop in a type R motor in it.
cheaper insurance ratesa and the power and reliability of a type R.
about reving a LS high, yes you could rev a LS as high as a gsr, but keep this in mind my R motor is reved up to 9600 rpm, pulls 206hp @ the wheels and when i come to a stop it idles really nice like its stock. i have yet to see a LS motor do that, sure you could make it with that hp but when you come to a stop the motor dies or it acts like it wants to die.
