bout to switch oils at 110k
Old 10-14-2003, 07:35 AM
Kha
eliteness hit me
Kha's Avatar
Default bout to switch oils at 110k
i have no leaks, bought the car from this old car at 100k, since then i put on almost 10k on. no leaks. been using valvoline high mileage 5w-30 but i think i can maybe go mobil 1 synthetic 5w-30?
inputs?
Old 10-14-2003, 08:37 AM
Amirked
Amirked's Avatar
you should be able to. . i did a lot of research into this myself and what you should do is do an engine flush first (depending on the product you just add it and run the vehicle for 5 minutes then drain the oil) - that will take out all of the old buildup - but i would really go with the 10w-30 as long as its not cold out. I switched my teg over a few months ago at about 82,000 and i've been running full synthetic mobil 1 10w-30 ever since.
some people will say it will make your car leak .. here's why it might- dino oil builds up over time and may cover some of your seals etc, if the build up gets too think the seals will dry out and shrink. If this is the case cleaning it out and exposing the seals to new oil may leak a little. . but supposedly the seals if they aren't to bad should absorb some oil and get thicker. However, if the seals are so dried out that they are cracked and you flush away that "oil seal" of sludged up oil you will get leaks. but i'd say 100,000 miles isn't that bad as long as the oil has been changed religiously. . good luck with that
Old 10-14-2003, 10:05 AM
Xymox007
Björkian
Xymox007's Avatar
Go synthetic. I switched mine over last oil change and haven't *knock on wood* had any problems since.
Old 10-14-2003, 10:58 AM
Spec R
Spec R's Avatar
I say stick to conventional dino oil. its cheaper, and I believe it was the synthetic mobil i was using that caused my motor to start burning oil...theres no proof of that, but i'll state this....
with 5w30 synthetic mobil, i was burning more than 1 quart every 1000 miles.
with 10w30 non syn Castrol (drive hard formula), it was up to 1500-1700 miles a quart.
now, with 10w40 non syn Castol (drive hard formula also), i've only burned less than half a quart, and i'm already at 1700 miles since the last change.
thats only my opinion though....its up to you Kha :thumbup:
DB Squad
Integra Forum Moderator
Old 10-14-2003, 12:06 PM
Kha
eliteness hit me
Kha's Avatar
man o man. fuuck that then im sticking with my valvoline high mileage and keep riding. im at 109700 and still running strong. i put on the 10k since june. i dont know if thats alot of not.
hmph
:thumbup:
Old 10-14-2003, 03:56 PM
Spec R
Spec R's Avatar
Yeah, I say stick with what you're using.
DB Squad
Old 10-14-2003, 08:18 PM
thx247
thx247's Avatar
The fact that you are running heavier oil has NOTHING to do with any of that....
Old 10-14-2003, 08:25 PM
Cheap Labour
Cheap Labour's Avatar
Damn, you guys have been burning oil like nuts. I go usualy 7-8k between oil changes using Pennzoil 10-W30. I end up burning MAYBE 1/4 of a quart between these changes. However, the oil that was in my car when I got it from the dealership burned nearly a quart after 7000 miles. I've got a '98 LS with 133k on it.
By the way, what sort of oil filters do you guys use? I've had the best luck with Fram, and their grip filters are great because I know of no wrench that could ever get to that filter.
Old 10-14-2003, 09:24 PM
Spec R
Spec R's Avatar
Okay smart-guy, why dont you be of some use and actually prove your point?
DB Squad
Old 10-14-2003, 10:10 PM
Epoch
CHRISTMASTIME IN IRAQ
Epoch's Avatar
Wow... even though I use Castrol Synth (I get it for damn cheap), I don't like to pull more than 3.5K per change... Call me old fashioned, but better safe than sorry...
I use STP filters... made by the same people who make Mobil1 and K&N oil filters, but only 2.99 :thumbup:
