simple question about aftermarket speaker install.
Old Jul 9, 2002 | 09:04 PM
ziggyziggy's Avatar
ziggyziggy
i am asian
Default simple question about aftermarket speaker install.
do i just pull out the factory speakers and attach the new ones or do i need some sort of special adapters for the aftermarket speakers, kinda like the idea of aftermarket headunits. i've never open up my door panel b4.
Old Jul 9, 2002 | 09:55 PM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
Default Re: simple question about aftermarket speaker install.
the stock speakers are two, (very short ), wires with a plastic harness on the end that plugs straight into the OEM speakers. if you plan to add aftermarkets with no adapter on the after market youll need to get your solder on and clip the harness off the stock wires. the speakers should fit in very easily, in my car its proly about 30 mins to do all four, 20 mins a pair or less.
Old Jul 9, 2002 | 11:29 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
when you buy aftermarket speakers, they dont come with the cute plastic adaptor like on your stock speakers. You can either get the harness so you can just plug it right in, or you can cut the plug off and either solder (if you have skills) or crimp the wires together. So long as you get the right size speaker, including right depth (which is a big issue w/most hondas) then it will be an easy experience.
Old Jul 10, 2002 | 06:16 AM
ziggyziggy's Avatar
ziggyziggy
i am asian
how much would the harness cost?
Old Jul 10, 2002 | 06:35 AM
Fujiwara Takumi
It's my first day.
i dunno where youd get the harnesses, except i know crutchfield will sell speakers with them built in.
Old Jul 10, 2002 | 06:47 AM
ziggyziggy's Avatar
ziggyziggy
i am asian
so i assume most of u guys just solder them on?
Old Jul 10, 2002 | 08:50 AM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
Circuit City, Best Buys, Good Guys, etc...should have speaker harnesses for $5.99 a pair.
Old Jul 10, 2002 | 08:56 AM
Fujiwara Takumi
It's my first day.
hmm, i learned somethign new today. rock on.
Old Jul 10, 2002 | 04:31 PM
b00gers's Avatar
b00gers
yea the harnesses arent too expensive. but they are practically useless to me since i always run aftermarket wires...=P
Old Jul 10, 2002 | 05:30 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
I don't solder mine on, I get the correct terminals to connect to the speaker and crimp them on. Like Will, I run my own speaker wire, usually monster cable.
