Clicking sound when engine is warm
Old Aug 23, 2007 | 05:18 PM
tuner9216's Avatar
tuner9216
Default Clicking sound when engine is warm
I have a 94 accord that makes a clicking sound only when under load and when engine is warm. It does not make the sound while at idle, while in park and revving, or while cruising.
Timing belt was replaced at 80k miles, valves checked and were ok. Distributor replaced with re-man (these are junk) at 86k and again at 86,008.
At 90k it now has this clicking sound, I've tried higher octane fuel, verified timing is correct, no success.
Any ideas?
Thanks, Dan
Old Aug 25, 2007 | 08:44 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
Who checked your valves? Did they verify they were up to spec or did they just "check" them?
Old Aug 25, 2007 | 11:36 AM
tuner9216's Avatar
tuner9216
They were checked and verified to be in spec, by a mechanic.
I took it to a mechanic today and they 90 percent sure it is the egr valve, they said it needs to be cleaned and a fuel system treatment. I guess I'll try that and see if it works.
Old Aug 27, 2007 | 09:52 AM
foot's Avatar
foot
Are you sure it's an engine noise?
Old Aug 27, 2007 | 03:55 PM
KaoticBRD's Avatar
KaoticBRD
Check your Idler pulley for the timing belt. Or make sure your Timing belt is tight if its too loose it will slap or flop and make a similar sound.
Old Aug 27, 2007 | 06:22 PM
tuner9216's Avatar
tuner9216
The fuel system treatment and egr cleaning didn't work.
I messed around with the timing a little and it affected the sound some. I went back to the parts store and swapped the distributor one last time for reman #3. This solved the problem. It probably would have been worth spending the extra $150 for a new distributor.
Thanks for the other ideas, I'm just glad it's done with.
Old Sep 14, 2007 | 06:39 PM
kotty's Avatar
kotty
Checked your timing belt and make sure that it is tight to loose..or maybe you should bring it to the expert to know what was the real damage.. also try to check your honda accord radiator,valve and fuel system..
