Lx2-1000???
Old Dec 7, 2006 | 07:46 PM
mr22na's Avatar
mr22na
Miss It.
Default Lx2-1000???
this isa power acoustik amp i bought ...to go with my type R...it is 2 ohm stable in stereo but not mono....what would be the worst thing if i put it two ohm mono with me type r...my other amp fried up an this is a quick replacement....the typr is dual VC but to get it to 4 ohm stereo id have to drill into my box an run wires from both VC to the amp..i dont want to do that..just looking for other peoples input thanks
Old Dec 7, 2006 | 10:17 PM
b00gers's Avatar
b00gers
What? So right now you are only using 1 voice coil?
Lets clarify this for everyone.
Post the model of the amp and the model of the sub.
Old Dec 8, 2006 | 08:11 AM
mr22na's Avatar
mr22na
Miss It.
i have the LX2-1000 power acoustik amp
i have the alpine type R DVC (4ohm VC's)
the amp is rated at 2 ohms X 2 at 280 rms
4ohms X 2 at 220 rms
4 oms X 1 at 560 rms
the amp is not rated 2 ohms x 1 ->this is the way i will be wiring it all up.
Old Dec 8, 2006 | 10:21 AM
b00gers's Avatar
b00gers
Theres a few ways to do it.
You can wire the voicecoils together to get a 2 OHM load and wire it to the amp without bridging it. But you will be only getting 280 watts and not using all of the amp.
You can wire the voicecoils to get a 2 OHM load and bridge it to the amp. Then see if that will bring it into protection mode. Obviously, if it does, then this set up wouldnt work. This is risky though.
You can also attempt to not wire the voicecoils together, but wire each one directly to the amp and give each voicecoil 220 watts. Just be very careful about setting the gain and crossover the same. Kinda risky and ghetto also.
h:
Old Dec 8, 2006 | 06:45 PM
dleccord's Avatar
dleccord
Quad 4 ohms down to 2 ohms?
Old Dec 8, 2006 | 09:14 PM
mr22na's Avatar
mr22na
Miss It.
i dont understand what your trying to say..please explain...i listed everything that i had above and what it contained as far as omhs
quad 4 O down 2 O ????
Old Dec 9, 2006 | 11:09 PM
dleccord's Avatar
dleccord
Quad 4 ohms comes from your two 4 ohm DVC subs, correct? Hence, Quad 4 Ohm. Meaning you can only wire them down to 1 or 4 ohms. I think 16 ohms is possible/necessary but don't quote me on that
Old Dec 10, 2006 | 06:16 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
He has one from what I've gathered.
Yes and no. Yes it would run for a short time. No it wouldn't last, it would heat up and go into thermal/protect.
Old Dec 10, 2006 | 07:53 AM
mr22na's Avatar
mr22na
Miss It.
yes i only have one type R DVC sub both VC are 4 ohms each...bridge together to one channel mono on a two channel amp...doesnt matter how long it last i got the amp for 85$ and i got a 4 year service plan for liek 15$...breaks return it,.....thanks fellas.[
Old Dec 12, 2006 | 02:28 PM
dleccord's Avatar
dleccord
So then the only thing you can do it run each channel to each coils. Dont forget to use only one channel from your headunit.
