intake manifold
Old Feb 22, 2006 | 09:12 PM
joflo95'ls's Avatar
joflo95'ls
Default intake manifold
wut up fellas, question bout this product. i'm interested in getting the skunk2 intake manifold and throttle body,will it improve hp at all on a stock b18b1 ls non-v with an already added injen cold-air intake? let me know what you guys think or know and give me some ideas on what i can do. thanks
jojo
Old Feb 22, 2006 | 10:14 PM
rugsr's Avatar
rugsr
How do my taillights look
well it did for my b18c1, the 95 GSR. i love it so i say go w/ it. only problem was that the I.M. inlet is higher then stock so the CAI barely fit. and when it did i had to move my strut bar. BUT i did feel more pick up. the TB im not sure on, i think id save the $$$
rugsr's Avatar
rugsr
Old Feb 23, 2006 | 08:58 AM
dubcac's Avatar
dubcac
I
It won't do much on a basically stock car. Once you have cams or boost, it'll help.
Old Feb 23, 2006 | 10:53 AM
rugsr's Avatar
rugsr
true, but there will be some difference. my IM was put on after my CAI and ehaust so mabye thats why i felt more juice
Old Feb 23, 2006 | 05:26 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
don't waste your money on the TB... unless your planning on doing a heavy all motor build.. the IM will make a slight difference just by letting your engine inhale a little easier... but in the end... the difference will be minimal ona stock engine
Old Feb 23, 2006 | 08:53 PM
rugsr's Avatar
rugsr
agreed^
Old Feb 23, 2006 | 08:58 PM
dubcac's Avatar
dubcac
I
It makes much more of a difference on the GSR, due to the single runner vs dual runner design. On an LS, it'd be hard to feel much of a difference.
Old Feb 23, 2006 | 10:26 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
True, and it also shifts the powerband further back into the mid-high end where the LS is lacking. I would stay away from it unless you have some decent cams and a strengthened bottom end to rev higher and take advantage of the extended powerband.
Old Feb 24, 2006 | 11:35 PM
joflo95'ls's Avatar
joflo95'ls
most of the cams that i see are for v-tec engines not non-v.what do you recomend for the cams and also,whats a simple but good way to build up the bottom end?
