TL Sway Bar installed.
Old Sep 25, 2005 | 10:57 PM
shonnv's Avatar
shonnv
7th Gen Coupe V6
Default TL Sway Bar installed.
Hey guys, I've just installed my rear TL sway bar today and man its the best mod ever for 30 bucks. Well I got lucky, the dealer qouted me $67 for the whole thing but some guy was selling a slightly used one for $20(shipped) and I bought the Bushings and the brackets for $10 from a local dealership.
Its pretty easy to install, took me about an hour and I did it without lifting the car. It fits real good, clear from anything on my V6 and damn the car is handling good.
Sorry couldnt take any pictures cause I did it at night but will post some pictures later. If anyone is insterested in a DIY, just drop me an email at shon.nv@gmail.com or just send me a PM. Cheers
Old Sep 26, 2005 | 05:40 AM
evolution's Avatar
evolution
早晨好, 先生們!™ 粉腸+ 春袋
Glad you enjoy it, I agree best handling mod for value.
Old Sep 27, 2005 | 02:46 AM
BONE's Avatar
BONE
I agree
Old Sep 27, 2005 | 04:01 AM
TinTin's Avatar
TinTin
Hong Kong
can you feel the difference?
do you mind a more detailed explanation of the improvments and such? thanks
Old Sep 27, 2005 | 04:14 AM
skabone69's Avatar
skabone69
Originally Posted by BONE
I agree
:werd: what a cheap easy mod that really makes a difference.
it makes the handling feel more neutral, it gets rid of a lot of the understeer.
Old Sep 27, 2005 | 05:20 AM
hoyoung02's Avatar
hoyoung02
HEAT:Shift_TechkaV
you must drive like a crazy basturd to get a understeer from regular driving h:
it's stiffer, so it doesn't give as much body roll as the stock accord's sway bar's would.
Old Sep 27, 2005 | 09:34 AM
shonnv's Avatar
shonnv
7th Gen Coupe V6
after installing it, I took it to a test drive, felt the ride a bit smoother on uneven roads. I can make sharp 20mhp turn on 35-40mhp and making a u-turn is alot easier. V6 cars are heavier than the 4cyl and I do feel a big difference.
All the accord do understeer as far as I know. I bought a coupe over a sedan cause I do drive crazy sometimes and I wanted the sportier look and feel.
Not only the Sway bar is thicker and stiffer, it is totaly different in the design thus provides a good response. here is a picture(courtesy of "mrksts")
top one it the TL and bottom is the stock
Old Sep 27, 2005 | 12:19 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Post DIY or ban. Sorry, those are the rules :happysad: Make some accurate drawings in MS Paint
Old Sep 27, 2005 | 01:16 PM
georgie's Avatar
georgie
could you install this on a 4cyl one?
Old Sep 27, 2005 | 02:05 PM
shonnv's Avatar
shonnv
7th Gen Coupe V6
Yes you can install it on a 4cyl as well.
The parts numbers of all the things you need are:
Sway Bar: 52300-SEP-A11
Holders: 52308-S3M-A00
Bushings: 52306-SEP-A11
Here is a DIY: http://syclone.motocrew.com/CG5/swaybar.htm
It pretty easy to do, once you go under the car, you will see the sway bar and where it is connected. Make sure you have all the tools and someone to help you pass the tools.
