Ignition timing issues
Old Mar 12, 2019 | 12:53 AM
trm4life's Avatar
trm4life
trm4life
Default Ignition timing issues
Ok so I have a 92 Integra GS with B18A1. OBD-1
I had a rebuilt dizzy on it for the longest time and eventually it started to have misfire issues at WOT. Used it for a good 2 or 3 years
I bought a new one, which didn't have a lock washer on the rotor screw and destroyed one of my caps, still got me home!
I took the 2 dizzys, and used mostly parts from the new one to build a functional one. Used it for probably over a year
Recently, again, misfires at WOT, bought another new one, and instantly I can tell it fires up much faster. Warmed it up and when I went to set the timing, The light was flashing at the TDC mark.
I had to adjust it fully to get it on the ignition timing marks, and I can only hit the first one. I'm not hitting the center mark. I can WOT 1st and second gear but seem to have trouble still, in 5th on the interstate if I give it too much throttle.
I'm starting to think my ECU is getting tired, I have another one, and intend to swap it out to see if I have any changes. Let me know your thoughts!
Old Apr 11, 2020 | 09:49 AM
Anthony Vu's Avatar
Anthony Vu
Default Smog failed
Hi, I have a bone stock 1995 Acura Integra LS special 4 door automatic with 276,000 miles. I recently had it smogged and results shows, Ignition Timing FB06 - Failed
Brand new Factory OEM parts replaced in the last 2 months - Fuel Filter, Water Pump, Timing Belt, Power steering pump belt, Radiator + all hoses / cap, Air Filter, Oil Change, Oil cap, Spark plugs and wires, no leaks throughout the car, valve cover gaskets, transmission fluid change, motor mounts and all suspensions. Everything on the car is original, except the DISTRIBUTOR. Can you help me on my next step, Thank you
File Type: jpg
File Type: jpg
pslsnakes
11
Dec 3, 2008 07:53 AM
Alfred5279
92+ Civic/EL & Del Sol
4
Aug 24, 2008 03:30 PM
91_accord
Accord
2
Nov 10, 2006 10:30 AM
pinealean
2
Jul 19, 2006 09:54 PM
sohcvtec01
Engine Swaps, Tech & Tuning
Jul 21, 2003 07:51 AM
