Finally got a lude, questions/suggestions?
Old May 15, 2005 | 09:27 PM
former v8er's Avatar
former v8er
Default Finally got a lude, questions/suggestions?
I got a 4th gen 93 Si w/104 k miles. My question is do I have to use premium fuel. Will it mess up the engine or just sacrifice performence? Plus is the time to change the timing belt on the engine?
anything else to know?
Old May 15, 2005 | 09:36 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
If it states either on the dashboard or the owners manual to use premium fuel only, do so. It will keep the engine running at its peak potential if you use the recommended octane fuel.
The timing belt is a good idea to do right away. A broken timing belt is bad news for the valves and pistons on close interference engines like Honda engines.
It may be a good idea to do a full tuneup with new distributor cap/rotor, spark plugs, spark plug wires, fuel filter, etc if you don't know when they were done last. It will give you better gas mileage and prolong the life of the car.
Old May 16, 2005 | 05:15 AM
99PreludeVTEC's Avatar
99PreludeVTEC
While you're on the subject, how often does it normally cost to get a tune-up from Honda?
Old May 16, 2005 | 07:47 AM
former v8er
plus it had a red SRS button, does that mean there is a problem with the airbag?
Old May 16, 2005 | 02:49 PM
StreetRacingCRX's Avatar
StreetRacingCRX
None
I always put the highest octane I can it cleans your fuel system like your injector and your valves. Hihg octance gas will not mess up your engine unless you put like octane 100+ all the time
Old May 16, 2005 | 09:26 PM
Provocateur
On permanent hiatus
It doesn't do anything unless the engine requires it. The engine doesn't take advantage of the extra octane, so you are essentially throwing money down the toilet if you put 91 octane in a car that can run perfectly fine on 87 octane.
Old May 17, 2005 | 09:24 PM
Ludemandan's Avatar
Ludemandan
Prelude tracktion
Congrats on the buy! I hope you love your lude as much as I do mine (second one). :driving:
Do you have the records from the previous owner, or know when this stuff was done? The timing belt should be done within 90k miles. If it hasn't been done yet, DO IT.
The SRS light should come on for a few seconds when you first start the car. If it doesn't disappear, you should take it to a dealer and see what's up.
And yes, put premium in there. I think it's made to take 91 octane, since that's the highest you can buy at most stations in California.
-Dan
Old May 18, 2005 | 01:28 PM
2legit2quit's Avatar
2legit2quit
You Big Dummy
^Yeah, whut he said.^ h:
