98 civic hidding stock HU and using new HU
Old May 1, 2005 | 08:18 AM
OblivionLord's Avatar
OblivionLord
Default 98 civic hidding stock HU and using new HU
I have a tutoral on how this whole procedure is done and its fairly easy.
The only damn thing it doesn't say is what wiring from the stock HU do I really need to connect to the aftermarkey HU so I can retain the keyless entry. Obviously I don't need to connect the speaker wiring from the Stock HU to the aftermarkey one.
Anyone got any idea?
Old May 1, 2005 | 10:35 AM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
there's two DIN slots in the 96-98 civics. One near the HVAC controls, another by the cup holders.
to keep my OEM keyless, I installed my aftermarket HU in the lower DIN, and kept my factory HU in the upper DIN. You can pull the main wiring harness for the radio through the dash, so you don't need to extend it. From there, I wired the harness to the adapter harness, but I ran 4 extra wires from the Power, Ground, Ignition, and Dimmer, and ran them up to the stock HU. then I used some slip-on clamps (the smallest I could find), wrapped them in electric tape, and plugged them into the radio in the propper places (takes a little bit of looking at the main harness and figuring where wires should plug into). Keep the green harness plugged into the OEM radio, and you'll be set.
another thing to consider (though I haven't seen anyone do) is the 98-02 accords and CRV have a different keyless receiver (its close to 8"x5"x1", small demensions), and it'll accept the plug from the green harness that goes into the OEM radio. I noticed this when I installed the OEM keyless system into my father '00 accord lx v6.
Old May 1, 2005 | 05:56 PM
OblivionLord
Does the installation kit for the aftermarket headunits work in the lower DIN area or does it looked jerry riged?
The tutorial says that you will need a reverse honda wiring harness for the stock radio and an aftermarket wiring harness. You then connect all 3 wires together (reverse harness, aftermarket harness and aftermarket HU wires).
Now I'll only need to connect these wires to the stock HU: Power, Ground, Ignition, and Dimmer.
thnaks
Old May 2, 2005 | 04:01 PM
19.3secS2K's Avatar
19.3secS2K
they sell a harness that is a y-connector. One female to two males. search and ye shall find
but yeah, an aftermarket cd player down there looks fine. Actually, the factory CD player belongs in that space (the 96-98's are component stereo's for some reason). Its the same cd player that goes in the first gen crv's.
its kinda hard to see here, but it shows what to expect
people like how I installed it. they say it looks like it was ment to be down there. plus, it makes nosey people think you have a stock stereo in your car if they're casually peeking in.
Old May 2, 2005 | 09:59 PM
OblivionLord
http://www.crutchfield.com/S-N3MpKar...p?i=120701720T
Well it appears like you said it is offered as a 1 piece. That takes care of that.
Now the question remains.. Do installation kits work on the bottom DIN so i can retain that clean interior look?
Could you take some close up shoots so I can see your handy work. Thanks
Old May 3, 2005 | 05:27 PM
19.3secS2K's Avatar
19.3secS2K
it bolts right in. the only thing you have to be careful with is putting soda's and shit in the cup holder (condensation+electricity).
basically, you'll take the lower center area off (around the shifter, really easy, 6 screws) after you take off that peice, you'll need to take off four screws for the HU/Cupholder peice (black plastic), then you'll need to take out the black filler pocket (two screws?), and then the cd player goes right in. reassemble.
give me a bit, too dark tonight, maybe I can get to it tomorrow.
Old May 4, 2005 | 09:11 AM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
after i had my HU installed i lost my keyless. It was no deal tho cuz i was having an aftermarket keyless and alram installed the next week. I also noticed that my dome light does not go on when my doors are opened. It only goes on when i actually put it to the on position. Does ne1 know how i can fix this
Old May 4, 2005 | 03:39 PM
19.3secS2K's Avatar
19.3secS2K
your keyless brain unit is integrated with the stock radio. There's a green harness that goes into the back of it, which is for the keyless system.
under normal circumstances, when you unlock your doors with the keyless system, the lights turn on. that green harness has two wires, which need to be making a complete circut in order for your dome light to turn on when you open the doors. You can do this by either keeping the keyless brain in the car (by either getting a differnt version thats just the brain/keeping your factory radio in the car one way or another, or you can just jump the wires)
and here's those pictures.... sorry they're blurry, but I left my tripod at my buddies house h: no install kit required, just the correct harness adapter...
File Type: jpg
File Type: jpg
File Type: jpg
Old May 4, 2005 | 10:41 PM
OblivionLord
I see a plastic piece that is surrounding your HU. Is that an extra piece that came with your aftermarket HU or is that just part of the HU itself?
Old May 5, 2005 | 04:59 PM
19.3secS2K's Avatar
19.3secS2K
you kinda answered your own questions because it did come with the HU, and it is part of the HU itself.
just about every HU I've ever seen has that trim bezel.
