confusion about amps
Old Mar 1, 2005 | 08:16 AM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
Default confusion about amps
could someone explain to me whats the difference between mono, 1,2,3 and so on channel amps?
Old Mar 1, 2005 | 08:40 AM
rooofey's Avatar
rooofey
mono r for subs
Old Mar 1, 2005 | 08:56 AM
amps that have 1 channel have one speaker output (+ and -), to 1 speaker. 2 channel amps can have two speaker outputs, so you hook it up to 2 speakers, 4 to 4 and so on.
mono's are used for subs, i assume mono = 1, they tend to create more power i think.. but i really have no idea about mono subs h:
Old Mar 1, 2005 | 10:06 AM
99IntegraGS's Avatar
99IntegraGS
Mono amps are for subs. You ARE NOT limited to one sub because you have a mono amp. You just wire the subs together in parallel or series (depending on what amount of resistance/ohms you want) and wire them to the one speaker output of the mono amp.
Take a look at this wiring tutorial at the JL site.
http://jlaudio.com/tutorials/wiring/index.html
Old Mar 1, 2005 | 12:23 PM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
ok that clarifies alot of stuff, so i dont necessarily need two amps for 2 subs. and from the looks of it according to the link you gave its really easy to hook up two subs to one amp.
