confusion about amps
Originally Posted by bxsnypa
could someone explain to me whats the difference between mono, 1,2,3 and so on channel amps?
mono's are used for subs, i assume mono = 1, they tend to create more power i think.. but i really have no idea about mono subs
h:
Mono amps are for subs. You ARE NOT limited to one sub because you have a mono amp. You just wire the subs together in parallel or series (depending on what amount of resistance/ohms you want) and wire them to the one speaker output of the mono amp.
Take a look at this wiring tutorial at the JL site.
http://jlaudio.com/tutorials/wiring/index.html
ok that clarifies alot of stuff, so i dont necessarily need two amps for 2 subs. and from the looks of it according to the link you gave its really easy to hook up two subs to one amp.
