How to Fill Transmission oil after draining
Old Jan 29, 2005 | 05:57 PM
acutee's Avatar
acutee
Default How to Fill Transmission fluid after draining
Hi All,
Anyone knows where to fill the transmission fluid for 2003 TL-S after draining? The manual said to remove the filler plug, but does not indicate where the filler plug is, and where to fill it through.
Do you fill the transmission fluid through the dipstick?
Is there any reason why we have to remove the filler plug? to bleed air, not to overfill, or to fill through it?
Thanks much
Old Jan 29, 2005 | 07:29 PM
lgbr's Avatar
lgbr
Wal-Mart Shopper
is there an overall diagram of the transmission? The filler plug for my car was as far back towards the firewall as possible.
Old Jan 30, 2005 | 07:59 PM
12yearhondatech's Avatar
12yearhondatech
The filler plug means exactly as what says it is .Yes you have to remove it. It should be located around the transmission mount its a bolt with a large washer head use a 3/4 14mm or 17mm socket and a long extention with a 3/4 ratchet. The hole is big enuff for a funnel. Make sure you fill it on level ground
Old Jan 31, 2005 | 10:02 AM
JimBlake's Avatar
JimBlake
I don't have a TL-S, but is it an automatic? Manual trannys usually don't have a dipstick. Autos usually get filled thru the dipstick. You don't have to worry about bleeding air, for either kind.
Old Jan 31, 2005 | 11:14 AM
acutee's Avatar
acutee
Default Re-Fill Automatic Tranny Fluid
12yearhondatech,
Can I re-fill the fluid through the dipstick? As JimBlake mentioned, I can fill the automatic tranny fluid through the dipstick. Is it right that removing the filler plug is to ensure it is not overfilled? I am not really concerned about over-filling the tranny since I will do it slowly and refilling with the same, a little more or less, amount I drained.
Thank you very much for your all info.
Old Jan 31, 2005 | 07:30 PM
12yearhondatech
No the filler plug is not for bleeding air out of the system or for not over filling either, its there to make it easy to use a funnel. It will not hurt to fill through the dip stick you just need to pour it in slow or it will burp out off the funnel and make a mess. Make sure you put the correct amount back in and please only use honda fluid it will make the transmission last much longer.
Old Feb 1, 2005 | 06:42 AM
acutee's Avatar
acutee
Default Automatic Transmission Fluid
Thank you very much for helping. I will do it through the dipstick slowly. The fluid looks kind of brownish to me. So, I need to drain it as soon as posible to avoid any problem. It is strange that Acura recalled my car when it was 33k miles to install the oil jet, but they did not replaced the fluid. It is now 40k. If they did replace the fluid, I don't think it would get browny so quickly. Or maybe they did not flush it, thus it get mixed with the old fluid and became browny quickly. Would it be a concern that the fluid is browny?
Acura TL-S 2003 Automatic Transmission.
Old Feb 1, 2005 | 07:38 AM
JimBlake's Avatar
JimBlake
That's NOT GOOD. (& it's more important than your other power-steering business.)
You can only drain about 1/3 of the fluid, since the torque converter doesn't drain. So drain/fill, then drive a few miles & do it again. Buy about 10 quarts & do it again & again until it stays clean. When you open the first new bottle you'll know what color it's supposed to be.
Check your manual about fluid level. Honda's a little weird. Most others you check with the engine warmed up, idling. My '98 Accord wants it warmed up & turned off. I think most Honda products are like that.
edit...
It just occurred to me. How many miles on that 2003? What's the warranty situation? Even if you change your own fluid, I'd certainly get on record at the dealer about the fluid turning brown.
Old Feb 1, 2005 | 09:14 AM
12yearhondatech
Honda trans. fluid is not exactly red unlike most transmission fluids it is a light brown in color.
Old Feb 1, 2005 | 09:35 AM
acutee's Avatar
acutee
Default Auto Transmission Fluid Brown
The vehicle now has 40k on it. I was going to bring it into acura dealer to quesion on the brown fluid, but you know how dealers are...if it drives okay, they would say everything is normal, or even suggest to change the fluid if I don't like the color. If it broke, then they blamed you for not maintaining it. You know how that goes... They never admit anything wrong. I just bought 4 quarts of Honda atf-z1 (will get another 6 to do multiple drains), and I can see through the bottle the new fluid is really rose dark red, not brown color (when I used a white towel paper to wipe the stick). I will just do it this time and see how it turns out. My brother had the vehicle serviced by dealer since day one, and recently at 37k. But, it appears to me they didn't do anything. I believe they thought the vehicle is new and there is nothing needs to be done. They just check everything off all good on the paper and send us the bill; paying roughly a thousand dollars for all the services up to now, for just oil changes, and replacing both air filters. That's about it. Everything else is just inspection.
Honda has good performance vehicles, but peace of mind comparision, is worst than others, and even civic.
Thank you very much for all of your helps.
