fall out of vtec?
Old Jun 30, 2004 | 03:13 PM
pbizzlegsr's Avatar
pbizzlegsr
Default fall out of vtec?
after having my car dynotuned, my vtec is set to 5200. i notice when i redline first and go into 2nd that i fall out of vtec for about 200rpm then get back into vtec..is that right? because i was told that youre suppose to be in vtec once you go into 2nd..or since it was dynotuned and set there for a reason its okay? thanks
Old Jun 30, 2004 | 04:05 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
What tranny are you using? GSr?
Old Jul 1, 2004 | 09:58 PM
Kai's Avatar
Kai
Rotorphile.
As txhatch is getting at, gearing is very important, shorter gears are much less likely to drop you low enough to get out of the VTEC range then longer gears.
Isn't 5200RPM about stock engagement?
If it really bothers you, adjust the engagement point down to match it, but if it has been dyno tuned to be there, just leave it.
Old Jul 2, 2004 | 01:46 PM
Snoopy's Avatar
Snoopy
been there done that
4400 is stock engagement on a b18c1
Old Jul 2, 2004 | 02:31 PM
LT's Avatar
LT
The deer had to die!
if you raised the VTEC point, you will drop out when shifting at redline. Are you using a V-AFC? If so, you can set the High to Low cam switchover lower.
Old Jul 5, 2004 | 12:51 PM
2G_GSR's Avatar
2G_GSR
Isn't it 4400 on a c5
Old Jul 5, 2004 | 02:15 PM
LT's Avatar
LT
no...on a GSR the L->H cam switchover is @ 4400. Then, since the c1 utilizes a dual-stage intake manifold, the secondary runners open at 5750.
the vtec switchover on the ITR is 5400.
Old Jul 5, 2004 | 06:37 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Actually 5700 @ WOT. h:
