Transmission GRIND
Old May 3, 2004 | 12:06 PM
01teg-R's Avatar
01teg-R
Default Transmission GRIND
I was just wondering if anyone was having the same problem as me... say ur driving down the road and you decide to get on it in 1st,2nd,3rd but after 3rd u wanna just put it in 5th and cruise... does ur transmission grind at all... if not what do u think it could be? how much to fix it??? thanks
Old May 3, 2004 | 12:29 PM
Chris N's Avatar
Chris N
Transmission syncros. If you have that problem only when going into 5th, then its just your 5th gear synchro.
Old May 3, 2004 | 01:39 PM
sensei's Avatar
sensei
My 5th synchro is shot too, a new trans according to Acura is ~$2100, a 5th gear synchro and hub should be a few hundred bucks in parts.
Do yourself a favor and change the fluid and replace it with Honda MTF, and that should help your grinding. Eventually though, the synchro set will have to be replaced.
Old May 4, 2004 | 08:24 AM
01teg-R's Avatar
01teg-R
thanks for the feed back... ive also heard good stuff about the gmc syncro mesh i believe thats what its called.. but the weird thing is it only happens when im going from vtec in third to 5th skiping 4th i dont know why i do it but sometimes i do... but any other time it doesnt do it
Old May 4, 2004 | 09:00 AM
.RJ's Avatar
.RJ
Go Fast Crack Whore
dont use the GM stuff.
RJ - who's thinking about switching to redline MTF
Old May 4, 2004 | 10:41 AM
cheezthis's Avatar
cheezthis
sound/acoustical engineer
Redline MTF...I've had mixed results with it. At first, it felt great. Within a few months, it was terrible. When drained, it was actually foaming.
I'm happy w/honda mtf again. Try the redline stuff and see how it works for you.
Old May 14, 2004 | 08:16 PM
01teg-R's Avatar
01teg-R
how hard is it to change you trans????. fluid or should i wait until im having a new final drive put in my car?????
Old May 29, 2004 | 11:28 PM
CanadianR's Avatar
CanadianR
It's quite easy to do. There's a plug underneath, at the bottom of the case, you drain the fluid, put the plug back in, remove another plug a little further up on the tranny case and fill with gear oil just until it's level with that upper plug hole, then put the plug back in. It'll take about 2.2 litres to fill it. If you drive the car hard i'd say to change your fluid a couple times a year, or maybe even after every HPDE you do if you use Honda MTF, and once a year if you drive casually. You can't be too careful with your tranny, it seems many people overlook changing the fluid often.
Old May 30, 2004 | 10:00 PM
01teg-R's Avatar
01teg-R
thanks man for the info... i think im going to change my trans fluid this weekend coming up i hope i dont have any problems...
Old May 30, 2004 | 10:14 PM
CanadianR's Avatar
CanadianR
no problem. It's quite a bit easier if you have access to a lift, but still doable without. You shouldn't really have any problems, but a good idea would be to attach about 1-2 feet of hose to the end of a funnel to pour the fluid. I'm not sure what diameter of hose to use, basically small enough to fit in the plug hole, but big enough that the oil will flow through at a decent rate. If you don't make this you may have a really hard time getting the fluid in. Hope that helps you some.
