95 GSR tranny problems please help!!
Old Apr 23, 2004 | 10:11 PM
gsrvtec95's Avatar
gsrvtec95
Default 95 GSR tranny problems please help!!
OK heres the deal I have a 95 GSR with 151,000 miles on it. The other day I started noticing that when I shifting from 2nd to 3rd I got a grinding noise. But it only does it when im going over 4500 RPM anyhting under it doesnt do it anything after it does. I changed the fluid about a year and a half ago using full synthetic 10W30 motor oil. I have been told that it is probabaly the blocker ring going bad. I mean how long should that tranny last?? If anyone has any suggestions please let me know. thanks shwnoff@msn.com
Old Apr 24, 2004 | 06:29 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
:eek3: You put 10W30 motor oil in your transmission?? The grinding is probably coming from high mileage but, I would drain that oil asap and put Honda MTF (manual transmission fluid).
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Apr 24, 2004 | 06:32 AM
LT's Avatar
LT
The deer had to die!
definitely get the Honda MTF in there, ASAP! That tranny should last another 50K miles or more. It could also be a syncro, since they do spin UP the gears for high-rev shifting.
Old Apr 24, 2004 | 11:05 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
You guys are all scared of 10W30 like it's the plague or something. Up through '93, that's exactly what the Helms manual said to put into Honda transmissions. It certainly won't ruin the gearbox, that's for sure.
On possible cause of this problem is simply that the clutch is not grabbing as quickly as it used to, which causes the grinding on that shift. Otherwise your 3rd gear synchro might be wearing out.
Old Apr 24, 2004 | 12:22 PM
Atheist's Avatar
Atheist
Yea I'd say synchro. You can in fact use 10w30 oil, too. But I'd drain it and put GM synchromesh in there, a lot of people have had their grinding cured by this fluid.
Jay pelletier
3
Jan 30, 2006 01:17 AM
baseballer03
Apr 19, 2004 05:25 PM
eclipse spanker
9
Dec 9, 2002 02:42 AM
saber1
5
Aug 24, 2002 05:13 PM
97 CIVIC EX
11
Aug 19, 2002 07:43 AM
