Help me solve coilover problem
Old Apr 19, 2004 | 01:46 PM
3_diamond's Avatar
3_diamond
Default Help me solve coilover problem
I got skunk 2 coil over on my type r
It is adjusted 15 turns on the front, but they give me different wheel gap in the front.
Driver side is 1 finger gap and the passenger side is 2 fingers gap.
Why is that? I am bothered a lot because of this. Thanks much !
Old Apr 19, 2004 | 01:56 PM
BudMan's Avatar
BudMan
aka - dnfjeff
Can I assume your skunk 2 coilovers are height adjustable? The click adjustment at the top is there to adjust the damping ability of the shock, not the height. The only way to adjust the height is to change the adjust the shock body.
just my .02. Installing fully adjustable shocks can be a bit confusing if you haven't done it before.
Old Apr 19, 2004 | 01:58 PM
FunctionMotoring's Avatar
FunctionMotoring
HAN Approved Vendor
There are too many variables.. You are being overly cautious IMO..
The ground may not be level.. the Spring may not be completed settled.. Your car is not perfectly symmetric. etc.
I would use a measuring tape, instead of the finger method.
After adjusting did you pull the ebrake? Also, did you just install the coilovers?
Old Apr 19, 2004 | 01:59 PM
FunctionMotoring
HAN Approved Vendor
Skunk 2's are just a threaded body/spring.. similar to Ground Control setup.
Skunk 2 does not make dampers.
Good suggestion though, if he does have adjustable dampers, hopefully he isn't adjusting that
Old Apr 19, 2004 | 02:28 PM
Chris N's Avatar
Chris N
The reason is that the weight on the front left and front right of the car is NOT equal..
Same goes for the rear.
You have to adjust all four corners individually to your liking - as they will need some tweaking to get right.
This all assumes that you are on a level area.
Also, except for visual purposed, identical l/r right height is not important - cornerweighting a car usually results in slightly uneven l/r heights....
Old Apr 19, 2004 | 05:23 PM
3_diamond's Avatar
3_diamond
So...
A. Should I just adjusted to where the height is equal on wheel gap wise
or
B. Should I just let it be like that since the coil over is adjusted evenly on both side
Thanks!
Old Apr 19, 2004 | 06:13 PM
George Knighton's Avatar
George Knighton
What we did w/my Ground Controls when they first went on was to research what an OEM ITR's jack-reinforcement to ground was at all four corners.
Then we adjusted the Ground controls so that the height at all four jack reinforcement points was where the OEM ITR was, w/out counting threads.
Never had the first problem.
This is going to be a little rough, but short of actually having someone help you corner weight the car, I can't think of anything better to do.
Our own Scott Lear has an article on ITR suspensions in the latest issue of Grassroots Motorsports, and you might want to have a gander at that for the benefits of corner weighting.
Old Apr 20, 2004 | 11:00 PM
3_diamond's Avatar
3_diamond
I was thinking....H&R sport springs?
I just want to solve my problems
Thanks for all who contribute...I am still debating on what to do but certainly considering all ideas, especially measuring distance from the jack point.
Old Apr 20, 2004 | 11:03 PM
MyOldIntegra's Avatar
MyOldIntegra
I use to have a set of coil overs too, and I had the same problem.....
Like Chris N said, the weight on the car is not exactlly the same, and
therefore you won't get the perfect height when you adjust them the same,
I just use to play with it until I get the same height, it might mean that you have
to adjust the left / right side more...
Old Apr 21, 2004 | 08:45 PM
3_diamond's Avatar
3_diamond
would that interfere with car balance if i do that?
do you still have coil over on your car MyOldIntegra?
Thanks everyone..
97teg4dr
2
Mar 21, 2004 03:22 PM
4wdcivic
Engine Swaps, Tech & Tuning
9
May 15, 2003 01:58 PM
undrgrndhaqer
10
May 14, 2003 07:14 PM
jaxrunner
May 4, 2003 12:48 PM
AadosX
Accord
11
Mar 14, 2003 09:53 AM
