passenger axle
Old Mar 18, 2004 | 09:21 AM
integraguy_3's Avatar
integraguy_3
teAm coNcepTs
Default passenger axle
anyone know how to take off the front passenger side axle on a gen 3 integra???
Old Mar 18, 2004 | 09:38 AM
Daniel's Avatar
Daniel
1) Remove the wheel
2) Drain the MTF fluid from the transmission.
3) Straighten out the tab on the axle nut using a punch. Use a 32mm socket and breaker bar or 32mm socket and impact wrench to remove the axle nut.
4) You'll need to remove the lower fork with a 17mm socket and 14mm socket.
5) Pull the fork out. It will take some twisting and working, but it will come out.
6) See this thread on ball-joint seperation: https://www.honda-acura.net/forums/s...ad.php?t=12390
7) Remove the outter part of the axle from the hub. You can turn the hub to the side to gain clearance. The outboard CV joint will bend as well and just pull it out. You may need to tap it out from the front. Have someone hold the axle or use a bungie cord to hold it up.
8 Use a pry-bar between the transmission and inboard CV joint to pry it out of the transmission.
That should take care of it. Install in reverse order. The new axle should pop right in completely. If it's giving you resistance, have someone rotate it while you apply force from the wheel-well. Also you will need to install the drain plug from the transmission back in, then remove the fill plug from above it and fill with Honda MTF according to spec.
That's all the details I can think of now. Keep us updated as you progress and we'll help any way we can.
Old Mar 19, 2004 | 07:27 PM
integraguy_3
teAm coNcepTs
thanks man. we got it out of the transmission. now from the wheel part it just slides out?? or is there a special tool to take it out?
Old Mar 19, 2004 | 07:34 PM
Daniel's Avatar
Daniel
As long as you have removed the 32mm axle nut from the end of the axle, it should just slide right out of the back. Try tapping lightly with a hammer of it doesn't, or spray some WD-40 in there.
Old Mar 19, 2004 | 08:11 PM
integraguy_3
teAm coNcepTs
the 32 mm nut is out and weve been trying to get it out should we hit it on the outside where the nut is at?? all we need to do is put a new the cv boot in
Civic2Scooby
Engine Swaps, Tech & Tuning
Aug 10, 2003 09:24 PM
Daniel
5
Jun 20, 2003 04:27 AM
keefungliu
3
Jun 15, 2003 08:52 PM
veen
92+ Civic/EL & Del Sol
3
Jun 13, 2003 01:42 PM
Tirod
News & Rumors Archives
31
Mar 3, 2003 05:13 PM
