Rough Idle
Old Jul 27, 2002 | 06:39 PM
CivOnDubs's Avatar
CivOnDubs
Default Rough Idle
I just did my swap and the one of the last problems is a really high idle. It always idles at 1500RPM, and it should be at half that....My friends and I have come to the conclusion that the ground wire we got was shot, and very cruddy looking...so if I get a new ground or possibly another one in addition to a new current one. In theory should this fix the problem?
I dropped a b16a2 into 93 ex
Old Jul 29, 2002 | 07:57 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
this is gonna sound weird, but pull off the pipe for the intake. There are 2 holes inside the TB. With it running, plug them one at a time with your finger. I promise you won't blow your finger off. If that smooths out your idle, mess around with the wiring, and the placement of your Map sensor. It should take care of the problem. I had the same problem jsut taking my engine out, and putting it back in. If it dies when you take your finger off, don't worry. It's normal. Just restart it and start messing with wires again.
Old Jul 29, 2002 | 09:27 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
you may wanna check out your vacuum lines, TPS sensor.
map sensor also maybe.
Project EVA - The Track Package
Project EVA
Old Jul 30, 2002 | 07:55 AM
white lightnin's Avatar
white lightnin
Try adjusting the throttle cable. There is also an idle sadjuster too. Doubt its the ground.
yuckie4u
6
Dec 15, 2003 11:16 AM
ShastSmae
Nov 29, 2003 04:48 AM
bmxunderground
Engine Swaps, Tech & Tuning
Jul 10, 2003 07:21 PM
Singhg83
3
Dec 9, 2002 07:04 AM
jkraus
92+ Civic/EL & Del Sol
Jun 30, 2002 05:10 AM
