question about sound?
Old Jul 24, 2002 | 10:56 AM
abocic's Avatar
abocic
Default question about sound?
I have my power wire coming down on my driver side and my speaker and RCA on the other to my amp but there is still a sound in my speaker when im in stop and go traffic. what can i do?
Old Jul 24, 2002 | 11:04 AM
b00gers's Avatar
b00gers
check the ground wire....make sure the amp got a good ground.
if that doesnt do it, turn down the gain on the amp.
Old Jul 24, 2002 | 07:46 PM
arch iceman's Avatar
arch iceman
Also check your battery terminal and make sure your RCA connections are tight.
Old Jul 27, 2002 | 11:15 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
Default Re: question about sound?
stay out of stop and go traffic:dunno: If all else fails, replace the rca's you have and see if that takes care of the problem.
Old Jul 28, 2002 | 11:24 AM
LjN_728's Avatar
LjN_728
any other mods you got running...ie foglights?
Old Jul 28, 2002 | 03:51 PM
CivicPete's Avatar
CivicPete
i would check the entire cableing from the battery to the amp then make sure the power is on the opposite side ofthe rca's and make sure you have a tight ground....good luck
Old Jul 29, 2002 | 11:53 AM
abocic's Avatar
abocic
98 accord coupe i4. i have the oem foglights, projector headlights, panasonic monitor and dvd player, dc header, aem intake, greddy catback, msd plug wires, ngk plugs, jvc amp and two 8" subs (small ) cd changer. the brain of the monitor is on the passenger side and there is RCA's going all over the place, i have monster RCA going to the dvd player(up to the deck) and to the jvc amp(to the truck) and one to the cd changer all on the right side(power is on the left side). so all the speaker wires go out from the amp, going back down the same side of the RCA's(two front speakers).
Old Aug 1, 2002 | 03:04 PM
derf's Avatar
derf
Spec5
what is the sound? if its high pictched and kinda changed by RPM you have a bad ground.... if anything else it might be your RCAs are pickin up somethin
ericgordon123
Accord
5
Mar 12, 2008 03:09 AM
Kavikgold
Aug 1, 2006 09:58 PM
JDMAccordEX
5
Jan 14, 2003 09:44 AM
