clutch tech question
Old Jul 2, 2003 | 05:03 PM
AwwsChwA's Avatar
AwwsChwA
Originally posted by 1stGenCRXer
First gear's a funny thing sometimes, best I can tell you.
agreed. My 1st gear is quirky too sometimes. It's a combination of aging synchronizers, soft shift linkage bushings, and the alignment of the stars. I can tell you, though, not to force it into gear. Just release the clutch (in neutral), press it back in, and then first gear should engage. My tranny does the same thing from time to time.
Old Jul 2, 2003 | 09:24 PM
petrv's Avatar
petrv
Originally posted by LALno1
hey, since this is about clutches, here's a related question--my 96 RS integra has about 86K mi on it with the original clutch (background info but don't know if it matters). When I sit at a light with the car in neutral and shift to first to go, about 1/4-1/3 of the time, it won't go into gear. I have to double clutch. WHY DOES IT DO THIS??? It's annoying. I understand that there is a safety thing so you can't put it into first from second, but why not from neutral?
Your pressure plate is going bad, even if the clutch itself is not sliding. The same happened to my Prelude. If you go just a little (don't completelly stop), the 1st gear goes ok, not? I could not get the 1st gear only at completelly stop. After my clucth has been replaced the 1st gear goes perfectly.
Old Jul 3, 2003 | 08:51 PM
LALno1's Avatar
LALno1
Yeah you guys know what i'm talking about. Thanks for your input. Just making sure it's normal.
Old Jul 4, 2003 | 05:26 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
A clutch that isn't operating properly will give difficult shifting in all gears, not just first.
-Harry
AIM: NDcissive
