spiderwebbing on transmission.
Old Jun 22, 2003 | 03:33 PM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
Default spiderwebbing on transmission.
the bell housing at the tip of the tranny on a swap we're doing for my buddies :db: has some spiderwebbing on it. it looks like the housing has been shocked or dropped in some way. he thinks he may have done it with a jack when he was trying to change the clutch, but that sounds weird unless he really ****ed up bad...
anyway, long story short i was told you could have it arc welded back together so the webbing/hairline cracks are gone. if this is the case do you know what costs would be, and would the tranny have to be empty for such a feat?
Old Jun 22, 2003 | 04:46 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
It could just be casting stress marks. What you really have to evaluate is whether or not it's leaking fluid through the cracks, and if the cracks go all the way through. For the latter, you'd have to disassemble the tranny to inspect.
-Harry
AIM: NDcissive
Old Jun 22, 2003 | 08:58 PM
crxb16er's Avatar
crxb16er
yah just check for oil leaks if there arent any id suggest just touching up with jbweld in the particular cracks if u think they are bad at all, but trannies arent under pressure or nething like engines so simply filling the cracks should be fine unless u think itll breach structural integrity and cause something to fall apart, then the whole thing should be replaced.
Old Jun 23, 2003 | 05:06 PM
qtiger's Avatar
qtiger
If it's just the bellhousing I wouldn't worry about it unless it was serious.
Old Jun 23, 2003 | 05:25 PM
Fujiwara Takumi
It's my first day.
this is about what were talking about...
[20:22] thecode404: you think my cracks are about like this: http://www.jdmpro.com/picture/s80tranny2.jpg ? because chris says those are casting marks
[20:23] ABRN s k i e s: man
[20:23] ABRN s k i e s: i tried tot tell you thats what that was
Old Jun 23, 2003 | 05:34 PM
qtiger's Avatar
qtiger
Mine are way worse than that.
That looks like it's just surface cracking to me.
Old Jun 23, 2003 | 06:12 PM
1stGenCRXer
Yeah, that just looks like surface stress to me. I wouldn't really worry about it, seen much worse before.
-Harry
AIM: NDcissive
Old Jun 24, 2003 | 10:57 AM
crxb16er's Avatar
crxb16er
yep looks pretty normal to me, mine is alot worse and im not concerned at all, man u should see the bottom of my oil pan, the plug is so smashed that when u take it out its almost pointing upward, but still no signs of any leaks.
