Squealing belt?
Old Jun 13, 2003 | 08:06 AM
sleepin's Avatar
sleepin
Default Squealing belt?
My friend has a 96 civic DX that when he starts up in the morning it whines loudly. Once it warms a bit the whining stops, but once he turns on the A\C , it starts whining again even louder than when he started it.
I checked the A\C belt, and it seems really tight. I didn't have a straight edge(or anything to use in its place at the time) to measure the belt deflection.
Could the A\C belt being too tight be the cause of this whining?
Thanks for any input.
Old Jun 13, 2003 | 03:25 PM
drift's Avatar
drift
Flaccid Member
twist the belt. easiest way to measure belt deflection is to twist the belt. if you can twist it so that the edges of the belt are perpendicular to how it normally wraps around the pulley or more, they're too loose.
if you cannot twist it more than 45 degrees from horizontal, it's too tight.
Old Jun 17, 2003 | 06:49 AM
sleepin's Avatar
sleepin
Thanks, I'll do that.
Old Jun 18, 2003 | 10:07 AM
jung4g's Avatar
jung4g
Asianalize your car
could also be a AC compressor bearing... Be sure to check all of the belts...
Good luck
Jung
