99 Si.....
Old Jun 12, 2003 | 09:10 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Originally posted by Nightshade
As for Phiz...your an assclown buddy. Have you ever even swapped a motor with an OBD change? Different sensors and number of sensors, plug types, PIN settings, all kinds of stuff to changeover...not just removal of an air sensor like you must be thinking.
Hey your're right, I don't have experience in that arena, maybe you could answer some questions in this thread: https://www.honda-acura.net/forums/s...threadid=76010
I'm pretty lost, and could really use everyone's help.
thread starter, sorry again, for totally hijacking your thread
-PHiZ
Old Jun 13, 2003 | 07:45 PM
i want a civic's Avatar
i want a civic
Why would you want to run an OBD2 engine with an OBD1 ecu? OBD1 wouldn't be as efficient as OBD2 ecu right? He can just interupt the ecu memory's power, then just tune it with a piggyback or something. When he goes to smog test his car, the ecu won't remember anycodes.
Old Jun 13, 2003 | 07:55 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
There isn't an issue with efficiency, it's an issue with complexity.
OBD generations continually get more and more complex as the ECUs use more sensors to help tweak the fuel and ignition maps for the engine they're designed to work with. As a result, they're able to more accurately and precisely pinpoint faults in the system, which is what OBD is all about anyways, On Board Diagnostics.
-Harry
AIM: NDcissive
