popping noise from exhaust
Old Jun 23, 2002 | 07:26 PM
excitid's Avatar
excitid
Default popping noise from exhaust
what makes a car backfire
Old Jun 23, 2002 | 11:06 PM
Bl@ck's Avatar
Bl@ck
Sinner
usually it means the car is running really rich. the excess gasoline detonates in the exhaust causing backfire.
Old Jun 28, 2002 | 01:59 PM
chanluder's Avatar
chanluder
how do u fix that kind of problem?
Old Jun 28, 2002 | 06:16 PM
Gasoline Fumes's Avatar
Gasoline Fumes
Automotive Enthusiast
Ignition timing seemed to effect backfiring on my '84 Wagon. Advancing it reduced backfiring.
Old Jun 29, 2002 | 10:02 AM
excitid's Avatar
excitid
any other fixes
Old Jun 29, 2002 | 01:33 PM
Bl@ck's Avatar
Bl@ck
Sinner
is it just a pop pop pop backfire or is it a loud bang that sounds like a shotgun blast?
Old Jun 29, 2002 | 02:05 PM
chanluder's Avatar
chanluder
mine is just a pop pop sound when u let go of the gas
Old Jun 29, 2002 | 02:25 PM
Paul's Avatar
Paul
Eater of Rice
i have that exact same problem, does it have to do with a restricitve exhaust setup?
Old Jun 29, 2002 | 03:12 PM
AP2's Avatar
AP2
Moderator Alumni
It's actually the opposite, the more free-flow the system is the more likely you're able to backfire. Ever since I've taken off my silencer last weekend, I've been getting really mean backfires.
Old Jun 29, 2002 | 04:37 PM
taylormadem5's Avatar
taylormadem5
it could also be from your cam timing if you have adj. cam gears..my best friend has some on his car..we retarded the exhaust cam gear 2 deg. and it fixed it..it could also be from a free flowing exhaust...its just the exhaust gasses going through the exhaust..as long as its not popping like a backfire..i wouldnt really worry about it..you can check the spark plugs and see if its running rich..if it is...you may want to either advance timing on your engine..or get a Fuel Pressure Regulator to help this problem
jdm-style
CRX & Pre 92 Civic
2
Apr 24, 2006 04:08 PM
streetfame01
Accord
3
Mar 3, 2005 08:01 AM
Slacker
92+ Civic/EL & Del Sol
33
Aug 29, 2003 09:21 AM
NS98GSR
8
Aug 11, 2003 08:33 AM
HondaGangsta
Accord
12
Oct 14, 2002 10:05 PM
