Crx wont start,Popping noise comes from intake manifold?
Old Apr 8, 2006 | 06:17 AM
jdm-style's Avatar
jdm-style
Default Crx wont start,Popping noise comes from intake manifold?
I have a 90 dx crx..Last night i went to take the car for a ride cause i didnt start it for a very long time.....THen once i pulled in to my driveway the car just died out..BUt the lights were still on and the radio was still on..BUt the car would not start at all. Its not the fuel pump cause i check.Its not the coil or the rotor or the battery..I still have Gas...But when i try to start it, it wont start at all..It cranks over but its making a noise, It making a popping noise.I change the sparks pulgs,wire.......
Need your help peeps..
Thanks for the time and GOD BLESS
I check the fuel pump it still works...But the popping noise comes from the intake manifold.My friend said my timeing is backward.
TOday i tryed starting it agian it wont start at all..Where is all the main relay in a crx?
THanks guys for all your help......
Old Apr 9, 2006 | 01:51 PM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Spark,Timing,Fuel,COmpression? Check them and u will find ur problem. If you can hear ur fuel pump, it isn't ur Main Relay.
Old Apr 24, 2006 | 04:08 PM
jordanhxc's Avatar
jordanhxc
when this happend to me I had water in my cap take it off and dry it...worth a try?
