Missing Engine
Old Feb 27, 2003 | 01:51 PM
Speed Phreak's Avatar
Speed Phreak
Turbomafia
Originally posted by KrzyMoke
I still can not find my connector to jumper to get my codes? HELP
Do I need to jumper a connector to get the codes? Does anyone else have this year? If so where is the connector? Any help would be appreciated.
Aloha
Aight, my first question is that are you looking at the ECU once you turn the car on? If it flashes once when then key is turned to "ON" and then doesn't flash anymore, you have no current "codes".
Also the "timing jumper" you are looking for has nothing to do with showing the codes. It will however clear any codes from the ECU if jumpered. It is located either above the ECU bundled in the wires above it. *OR* - in the engine bay on the drivers side frame rail near the front of the shock tower.
A useless note is that the 88-89 CRX/Civic's had the timing jumper in the engine bay, the 90-91's had it inside above the ECU.
~Steven
Old Feb 27, 2003 | 03:34 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
~Steven
He never said "timing jumper"....
There is however, a "jumper" or connector that is near the ECU that you check codes with... your post about the jumper really doesn't have anything to do with his posts... not to start crap, but it doesn't make a whole lot of sense. :dunno:
Old Feb 27, 2003 | 04:15 PM
Speed Phreak
Turbomafia
Lemme throw some knowledge on ya then.
I'm not sure about the OBD-1/2 cars. But OBD-0 cars(like his 89 teg) have a single LED that blips flashes, and can be seen by looking through a small window on the cover of the ECU. You count off the number of blips to find your code. Also the OBD-O ECU's will throw a CEL/MIL when they are ACTIVELY ignoring or detecting a problem. What this means is that if your "check engine" light comes on, it means the ECU has detected a problem and is letting you know(duh). Some codes can be cleared by simply swithing the car on and off, others you'll need to track down(like a dissconnected sensor). However the ECU stores the "code" for the problem it detected in memory. Thus whenever you look through the window on the ECU to check your codes you are seeing a History of all the "codes" the ECU has throw since it's last reset or loss of power.
Now at this point you are prolly asking WTF this has to do with the "timing jumper". Well that jumper that you refer to has a dual purpose. It's primary purpose is to allow you to adjust your timing via the distributor. With the engine warmed up and the jumper in place you are able to adjust your base timing advance or retarded from it's stock setting. If you try to turn the dist. w/o this plug jumpered it won't affect your timing at all.
Now the secondary effect of jumpering that plug is that it forces the ECU to clear all codes from it's memory. Most people will tell you to clear the codes in your ECU, and wait till it throws the code again. This allows you to troubleshoot the correct code without chasing after previous codes that are stored in the history. The reason I called it the "timing jumper" is becuase that's what it's main function is. HTH
Old Feb 27, 2003 | 04:19 PM
westcoaststyle
You're right, my bad. Now that I think of it in that context the "timing jumper" term has a different meaning. I was soley thinking about CEL diagnosis and forgot the second use for the jumper. I am keen to all that you posted, but the thread owner may not be.
I'm used to my OBD1 motor too. You seem to have more info on the OBD0 stuff so you can take it from here.
Good info :thumbup:
Old Feb 27, 2003 | 04:23 PM
Speed Phreak
Turbomafia
Bahh no worries, the forum is here to spread knowledge and promote friendship among fellow car enthusiasts. Just doing my part :thumbup:
Old Feb 27, 2003 | 04:38 PM
westcoaststyle
:werd: as am I.
Old Mar 9, 2003 | 06:39 PM
KrzyMoke's Avatar
KrzyMoke
DaKine Brah
Well now that we all hunky dory, my question still stands. BUT I still can't find my connector to jumper together to get my engine codes and I don't see where to short out the other connector to time my motor? Any takers? HELP
