Missing Engine
Well Aloha All,
I'm new to the Inport crowd so bear with me as I work through my problems. Any hep would be greatly appreciated. This is what I've got. 89 Integra with the 1.6. All stock. My engine is idling ok but if I give it gas is sputters and feels like its missing. I am trying to see how to look for engine codes but it is very vague for my year car. HELP Please. Aloha Kimo |
Do you know what the code(s) that it's throwing?
http://jdmfan.com/index.php?information=dtc
This is a link to JDM Fan. This page defines all of the CELs. HIH :thumbup: |
Guy's he wanting to know how to check for engine codes, not what they are.
Look under your passengers floor board, pull the carpet back from under the dash section. You could see a metal plated bolted to the floor with (4)10mm bolts. The will be a small hole in the center of the plate, that'll let you see the ECU and if it has any code whats they are. You will see a single red LED that blinks off the codes. A single short blink = 1, a long blink will = 10, add together the blinks to get your code. If you have multiple codes, there will be a brief puase b/t code sequences. |
Yep Speed that is what I'm looking for. The book says to just turn the key on and check the codes but there is only one red flash meaning all is ok? I don't know if I just got bad gas or my sheite is messed up?
This is how to troubleshoot DTCs: http://www.jdmfan.com/technical/other/troubleshoot_dtc/
Originally posted by KrzyMoke Yep Speed that is what I'm looking for. The book says to just turn the key on and check the codes but there is only one red flash meaning all is ok? I don't know if I just got bad gas or my sheite is messed up? A single short blink is a code 1, which is the O2 sensor. |
I still can not find my connector to jumper to get my codes? HELP :(
Do I need to jumper a connector to get the codes? Does anyone else have this year? If so where is the connector? Any help would be appreciated. Aloha :cool: |
Originally posted by KrzyMoke I still can not find my connector to jumper to get my codes? HELP :( Do I need to jumper a connector to get the codes? Does anyone else have this year? If so where is the connector? Any help would be appreciated. Aloha :cool: |
hey, does your car just die for a second like it is almost shutting off then continue? and is it all the time at the same rpms or just once in a while randomly, cause I would get that problem once in a while randomly on my 93 LS and it turned out to be loose wires to the ignition module.....
