CEL help
Old Jan 7, 2003 | 03:29 AM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
ut oh. What are the chances that I damaged it?
I guess I have to keep looking for the right one.:yay:
Old Jan 7, 2003 | 11:18 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
The MES connector gets shorted when you want to reset the SRS light, so I doubt you could have damaged it.
Old Jan 16, 2003 | 07:52 AM
clickwir's Avatar
clickwir
I'm looking all over and all points are pointing to the one connector that I was messing with... it's possible that the paper clip I used was coated in something and was non-conductive. I'm going to try it again with something that I'm sure is conductive... question, is there possibly any damage to just having done what I did? Essentially what I did then is just unplug the connector and didn't short it (I'm assuming) is that damaging at all?
Old Jan 16, 2003 | 09:13 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Did you plug it back in?
Old Jan 16, 2003 | 10:57 AM
clickwir's Avatar
clickwir
Yup. Right after I was messing with it. Everything seems to be ok.
Old Jan 16, 2003 | 12:36 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I'm not sure if this applies to all Preludes, but it might be of some use:
In order to get the code you'll need to find the service connector. On the 5th Gens it's on the right hand side of the centre console underneath a carpeted panel that just pops right out. The connector looks like a telephone connector and is plugged into a blue plastic piece that just serves as a holder. Unplug it and you'll see that it has two sockets in it that lead to two wires.
http://www.hondaprelude.to/main_checkengine.html
