Need Help Troubleshooting? Engine rattle.
Old Dec 10, 2002 | 01:23 PM
00BLKV6CPE's Avatar
00BLKV6CPE
Default Need Help Troubleshooting? Engine rattle.
I have a '95 Civic EX (1.5L) and it is making a noise that sounds like a bearing rattle in the motor. It gets louder with the RPMs but is not present at idle. It kind of sounds like a marble knocking around. No loss of power and otherwise runs great.
Could it be anything with the alternator, AC, or timing belt area. It has 96,000mi. I'm being hopeful.
Any ideas of what to look for would be appreciated very much. I am mechanically inclined but have not done much on Hondas (they never break )
Thanks in advance!!
Old Dec 10, 2002 | 03:00 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Sounds like a loose timing belt and/or valve out of adjustment.
-Harry
AIM: NDcissive
Old Dec 13, 2002 | 06:45 AM
00BLKV6CPE's Avatar
00BLKV6CPE
Could I do the timing belt at home or are special tools required? Two different people have mentioned to check the water pump. I've never heard of a water pump making this type of noise but I'll listen to any suggestions. Thanks for your reply!
Old Dec 13, 2002 | 08:09 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
You'd have to be able to take the crank pulley bolt off, and most people usually have trouble with that. Beyond that, you would need a jack, jackstands, a socket set, and basic hand tools.
Old Dec 13, 2002 | 08:45 AM
cvc2k's Avatar
cvc2k
and timing gun :-)
