Mapping on P30 ecu
Old Jan 25, 2008 | 03:22 PM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
Default Mapping on P30 ecu
Having been confused by a idle problem after checking everything is ok (sensors and vacuum leads) i checked skunk 2's website only to find that with my cams, im going to have to reduce fueling by 20-30% up to 1500rpm to have a smooth idle.
I now need a good basemap (standard or similar to my setup)
Could anyone on here be kind enough to give me a copy of theirs?
Heres my setup-
B16a2 block
B16b (ek9) pistons
B16a2 head (skimmed by 30 thou)
Skunk 2 stage 2 cams
compression ratio 12.0.1
B16a2 intake manifold with STD 58mm T/B
B18c ITR manifold
At the moment im running standard timing with no retard or advance, i still need to 'degree' the cams.
Dont mind what software it is as i will just download the program, however i would prefer crome.
Thanks for any help, ste
Old Jan 28, 2008 | 09:22 AM
B16a2VTIguy
Built B16a
BUMP!!
Also, my head sounds really tappet-ish, clicky.
When i rebuilt the head all the LMA's seemed 'free' enough and the clearances are set to 0.006 exhaust and 0.008 exhaust.
Any ideas?
