performing engine swap, should i swap out trans
Old Jan 28, 2008 | 12:17 PM
grease_panther's Avatar
grease_panther
technician
Default performing engine swap, should i swap out trans
Im thinking i should swap out the automatic trans and go with manual. Im swapping a 1.5 SOHC out of a civic for a B18 out of an integra. will i have to change the dashpod? and make my own linkage what do you think. and if anyone wants any thing from a 90 Integra or the engine/trans from a 93 civic ill be parting them out during the swap.
Old Jan 28, 2008 | 12:30 PM
NOPD's Avatar
NOPD
Come in My Hole
I did exactly that 6 years ago. It's a straight swap if it's a b18c1, the only thing you'll need is to weld on a manual transmission mount from a manual civic. The dash cluster needs to be change too if you want an rpm gauge. if it's any other b18, I can't tell ya
Old Jan 28, 2008 | 01:33 PM
umop-apisdn's Avatar
umop-apisdn
Allergic to vitamin D
...and an ECU, pedal assembly, clutch MC, center console, the list goes on and on. Too much of a headache for too old of a car, but to each his own.
Old Jan 28, 2008 | 01:49 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
a lot of work.
1. auto to manual, you'll need a new ECU, pedal assembly and clutch MC as said.
2. you plan to throw an OBD0 motor to an OBD1 chassis. You'll need to make sure you have all the right sensor/emission equiptment if that matters in your state. It is illegal in most.
3. going from hydraulic type transmission to cable type transmission (chassis wise) may require a new cable conversion transmission mount
4. you may need new engine mounts as the rear mount may not bolt up from the DA Integra.
...and a bunch of little stuff that adds up.
Old Jan 28, 2008 | 01:55 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Moved to Engine Swaps & Tech...
Old Jan 28, 2008 | 02:41 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
If you want a manual b18 buy a car that has a 5 speed. The money spent on the auto to manual could be spent on a different car that has a manual tranny.
