TURBO help
Old Oct 14, 2002 | 02:46 PM
KurUpTedEL's Avatar
KurUpTedEL
of yahoo
sum site
sjus listed the dsm turbos and uprgrades n crap
so 7000 rpm at 6 psi is no prob
Old Oct 14, 2002 | 02:51 PM
KurUpTedEL's Avatar
KurUpTedEL
PM ya
Old Oct 14, 2002 | 03:07 PM
DarkLightning's Avatar
DarkLightning
Originally posted by KurUpTedEL
of yahoo
sum site
The site I found stated the T-25 was good for at least 25 LBS/MIN which is higher than you'll need...
Old Oct 14, 2002 | 10:14 PM
KurUpTedEL's Avatar
KurUpTedEL
wat are some other stock D series cars that come with turbos that will fit my D series car
the manifold/downpipe .with the dsm t-25?
Old Oct 14, 2002 | 11:19 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
No D series Honda engine ever came with a stock turbo.
Old Oct 15, 2002 | 07:35 AM
T-RO's Avatar
T-RO
This place has some good info, and its on a Teg too.
http://www.cse.uconn.edu/~yelevich/turbo/turbo.html
Good thread here guys. I'm gonna do a custom turbo too one day on my EX. Trying to learn what I can... Mabye one of those T-25's would help. Hmmm :thumbup:
Old Oct 15, 2002 | 04:43 PM
KurUpTedEL's Avatar
KurUpTedEL
hey guys i just found this kit
but tryin to figure wa kinda turbine it is .the tdo4?
seems good Greddy turbo kit for sale. It includes: manifold, turbo, downpipe, stainless steel feed/return lines, Greddy fmu, Greddy type s bov, type 31 intercooler, all piping, all vac hoses, check valves, tapped oil pan for D16Y8. The turbo was on my car for 3 months, intercooler was on for 1 month(brand new). Everything works perfectly
all i need is a FPR.turbo time if i want one.and im done his comes with everything.....right?
jus tryin to see if the turbo is 2 big.it was on a 99 civic EX in canada
so i take it those cars come with A/C
Old Oct 15, 2002 | 05:29 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Yes, that comes with a TD04. It's a small turbo, and spools up quickly. The type 31 is the smaller GReddy Civic intercooler, and should be fine for your needs. An FPR would be useful, but not absoultely necessary. Yes, the kit will fit your AC fine. Make sure you get a boost gauge, and a BOV if you have the money. You'll need a boost controller if you want to turn up the boost, and when you do, you'll need an inline fuel pump so you don't lean out.
Old Oct 15, 2002 | 05:48 PM
KurUpTedEL's Avatar
KurUpTedEL
it comes with a greddy blow off valve type S and im gonan buy boost and a/f guages and maybe a EGT and most likely buy a FPR
do i need his tapped oil pan for the d16y8?
i can tap mine...or is better to by a tapped one so i can have a good oem one just for the future when id ecide to take the turbo off
prolly stay at 6 psi though........might get turbo timer.but maybe later
Old Oct 15, 2002 | 05:57 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
You don't NEED his pan, but if it already has the return flange in it, it'll save you the trouble of tapping yours, and you can just swap his pan on. Stock boost on those kits is between 4-5lbs.
