TURBO help
Originally posted by MrFatBooty
How did you compute air flow based on bore/stroke?
I wouldn't take their horsepower or torque numbers to heart, but the rest (engine capacity, CFM, etc.) is straight forward math & physics so there's very little to screw up on.
wat type is the garret turbo that u got at home?wat conditon ?and how much?.reason why i chose the 14b is cause it "should" do a decent job.second there pretty cheap to buy and theres a lot out there
will the garret fit my greddy manifold (question A) and second do the job?
it take it its smaller so it would have abetter chance in fitting with a A/C
[shameless plug]
I have two low mileage T-25's here (and a Garrett T3 42 Trim should anyone else be interested). PM or email me privately for a price, but I want to get these out of here so I'm flexible.
[/shameless plug]
since the manifold is off a 93 del sol with obd1
and my car has obd2
how can i put the existing sensors into the downpipe and crap
so the engine light dont come on?
and my car has obd2
will the t-25 spool up fast (i take it it will)..around wat rpm?
and will boost last until around 7000 rpm
or will it run out before then cause the turbos so small
Spool time we can only guess at, but it won't be bad.
