oil pressure problem on a b16a
Old Jun 9, 2007 | 02:37 PM
daddiodanger's Avatar
daddiodanger
bad mo fo
Default oil pressure problem on a b16a
i got a code 22
i checked my wiring , pulled the vtec assembly, cleaned it and reinstalled. it was still throwing the code.
i haven't put together a oil pressure gauge yet to check the pressure.
i'm thinking i'll replace the sending unit, next.
i was just wondering if anyone has had the same problem and if anyone has any suggestions.
Old Jun 12, 2007 | 08:28 PM
daddiodanger
bad mo fo
Bump
Old Jun 12, 2007 | 10:38 PM
2001TEGGSR's Avatar
2001TEGGSR
Get a helms and properly diagnose it, rather than replacing random parts until its fixed. You'll surely save money this way. I.E. Check for oil pressure, Use a volt meter to check the sending unit, etc.
Old Jun 13, 2007 | 08:25 PM
daddiodanger
bad mo fo
that kinda doesn't help
the first thing i did was break out the troubleshooting flow charts and a multimeter, however without one of those stupid PGM-FI test harness' it kinda hard to shoot wires
the flow charts only help so much
i need to know it anyone had similar problems IE: blocked pickups, clogged passageways, nonworking pressure regulator, oil pump, what ever
Old Jun 13, 2007 | 11:39 PM
2001TEGGSR's Avatar
2001TEGGSR
Theres not many things that could obstruct the passages to the point where you'll throw that code, it would spin a bearing quick. And a sure sign of this being the case - you'll here knocking and the engine won't run for more than a few minutes before you deprive a bearing of oil.
Does it run without knocking and clanking?
Can you verify the car does in fact have oil pressure?
Did you check for continuity at the pressure sensor & wires, like the helms states?
If it runs ok, I am willing to bet on the pressure sending unit or wiring. Good luck.
Old Jun 15, 2007 | 05:00 PM
daddiodanger
bad mo fo
thanks,
i'm not driving it i'll is better, but the engine seems perfectly fine
Old Jun 21, 2007 | 05:52 PM
daddiodanger
bad mo fo
BTW: i fixed the problem. the problem was a corroded ground wire, for the vtec oil pressure sensor. it looked fine untill i pulled it off and the connector fell off.
so thanks for all the help.
