Td05H Turbo/Manifold Spacer?
Old May 5, 2007 | 09:33 AM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
Default Td05H Turbo/Manifold Spacer?
Ok, so I get the turbo/manifold mounted in the car last night and there are some clearance issues. My downpipe hits the AC compressor and the wastegate actuator on the turbo hits a bleeder valve on (I think) a slave cylinder on the front of the block. I measured with a pretty ghetto spacer, and it looks like with about 1" of drop from the manifold will give me all the right clearances. Question is, does anyone know where to find a turbo to manifold spacer plate? I can't seem to track any down for the Td05 bolt pattern...I might resort to having one machined at a local shop, but it might cost a fortune. I was thinking of taking a gasket to them, since it's pretty much the right dimensions and having them machine that shape only an 1" thick instead of 3/16" or whatever the gasket is. But I'm hoping to find one online, so if anyone has one or knows where to get one, I'd really really appreciate the info!
Thanks in advance!
Old May 7, 2007 | 08:57 AM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
No one knows? I think I'll just have one made....
Old May 7, 2007 | 10:16 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Your A/C is probably going to have to go and you will have to make other modifications for things to fit. A spacer is not the right way to go about this.
Old May 7, 2007 | 11:44 AM
mberndt's Avatar
mberndt
Actually, a spacer will work great... I have one and I know of a couple people around me using steel plates to mount DSM and Subaru IHI turbos...
I have a TD05-14B mated to a T3 turbo maniold, using a steel plate.
I had the plate AND the exhaust turbine housing custom machined for my setup and it works great. Although it cost me $175.
I also modified the Wastegate actuator and I was able to keep my A/C, using an aftermarket FAL-thin style fan. Although I'm prob gonna remove this now, as the car is no longer my DD.
I highly doubt you will be able to find one already made, best bet is to have one made. Besides, you will need to have the exhaust turbine machined so that you can attach the turbo.
Want some pics? I have my motor out on my stand and my turbo ready to be ported...
Old May 7, 2007 | 03:22 PM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
Dude at the local machine shop is making one for me. With this 1" drop spacer, I can keep my AC because the downpipe clears it fine, and the wastegate actuator doesn't hit that little bleeder valve anymore. I did a mock up fit, everything fits perfect. My only problem now is finding a thinner fan to go on the radiator.
I did find some plates on Ebay but they were only 1/4" or so thick.
Old May 8, 2007 | 09:48 AM
mberndt's Avatar
mberndt
yeah, 1/4 inch thick is way too thin...
My plate is prob at least 1" thick... If it's not this thick, it would be difficult to mount the plate to the manifold, then bolt the turbo to the plate...
Basically, to attach the plate to the turbo manifold you need to conter-sink 4 bolts in the plate... Then attach studs to the plate and bolt down the turbo on the studs...
But, if you don't have the turbine housing machined, I don't see how you are going to attach the 4th bolt, as the turbo normally bolts to the manifold...
Old Jun 30, 2008 | 08:44 AM
b1ackhawk's Avatar
b1ackhawk
So in order to keep AC on the b18, aside from the proper manifold, you will need a thin A/C fan? Anything else? Special downpipe?
Can anyone with turbo and A/C post pics of the engine bay and fitament?
Thanks!
Old Jul 1, 2008 | 05:41 PM
Spec R's Avatar
Spec R
Thanks!
it really depends on the manifold/turbo/downpipe you're running.
the reason i went with the greddy kit was that the manifold/turbo/downpipe/downpipe elbow allowed me to keep the ac, powersteering, and stock fans.
DB Squad
Integra Forum Moderator
