Also, I will be goign with the flat Faced valves, for a bump in compression, so the thin headgasket coupled with the flat faced valves should work niceley.
If your having head work done, I would go with supertech valves. They are available in a flat face design, and are nitride coated. Proven strong several times. Make sure you use retainers with a "snap fit" design, they don't wear as quick. RM or Supertech valve springs and retainers are my preference.
I am going to use the Supertech valves, I think, and go with the Rocket motorsports cams and valve springs, not sure. But I am looking to make around 220 to the wheels with full headwork and tune. Is it possible to do that and can I go higher!?
i thought a stock usdm itr motor already made about 195 hp is that at the fly wheel?? hell i think a jdm itr motor puts out 220 but again could be at the flywheel
yeah but the the usdm itr wheel horse power is more like 170-175 at the wheels and the jdm is about 200 at the wheels. the goal with any N/A or turbo set-up is Wheel horse power!
