Dart Block
Im looking to build a dart block. I got a shell and itr suspension coming. Turbo it deffinitly a must. Low comp pistons, micro polished itr crank, crower rods. i have a few ideas but i figure some of you guys can give me some imput on good products and bank for buck.
just find a b18c block and have it sleeved. it'll come out much cheaper than a dart block. remember, dart blocks are BARE. they only come with the main caps so you still need a donor block for all the little odds and ends.
the only advantage i see a dart block has over a regular sleeved b18 is you can get one in a tall deck height so you can run a stroker crank and long rods. other than that i see no other reason to get one.
besides, the real weak point with a b block when pushing lots of power are the sleeves. at which point you just resleeve.
ok so then after sleeving whats a real good turbo setup im looking for reliablity and enough power so i have traction... i was thinking towards 350 like 325 range... im putting a role cage and want my tranny to have a LSD...
If you are only shooting for 350whp a Dart block is way overkill.
www.peakboost.com
afi
reliability is all in the build, tune, and the way you treat it
