Running Rich...
Since this post, I've gotten the B&M FPR and B&M FP gauge (that goes onto your fuel filter). The ITR FPR puts out 50PSI
Stock GSR FP should be 37-38 from what I understand. So, I brought that down. I also got an air/fuel meter, but haven't hooked it up yet.
It's at the shop right now getting tuned. I'll get it back next week *hopefully*.
narrow range af gauges are all but useless i had a turbo integra ran it for a few months so rich that my cat clogged and exploded ended up coming out the end of my exhaust in pieces no bigger than a marble dont trust them trust the dyno and their wideband
Originally posted by TeHJuSTiN
You eventually might want to go to DSM 450cc injectors. You might also want to check your fuel pump, my car would die or jerk and then I replaced my fuel pump and it ran fine.
Thanks for the info!
Originally posted by westcoaststyle
Couldn't I lean it down with the adjustable FPR? I I give the injectors less fuel pressure, won't they spray less fuel?
Can running too rich damage your engine? From what I understand, the cylinders could become gas-soaked causing fuel to get pass the rings and into the oil. Then you have the potential problem of oil break-down and internal parts wear.
The reason I ask is because I have a 92 CIVIC hatch with a new 2.0litre build from Import builders. I'm running a T3/T04E garrett and a Hondata Stage2B ECU. My 720cc injectors are dumping gas like mad. But I can't get to ATL until next week to not only have the car dyno-tuned, but tuned for daily driving as well.
