they're different in that they're necked and lighter. and they will fit.
Yes, they will fit and I will confirm this. I am running 7 GSR intake valves and 1 ITR valve. :exnbp:
It was all the dealer had at the time when I bent a valve.
with my built head set-up..........what compression should i go for with a gsr block........someone recommended like 9.8.1 or high nines for daily driver application but i was thinking that this might be a little low? My head is almost built and i wanna decide wat im gonna do before the machine shop is done.
If you don't intend on boosting, that is too low. For an N/A built 11.5-12:1 would be a good compression ratio.
Yeah, that shouldn't be a problem. I am assuming you have some sort of engine management lined up because you can't just slap all this together and expect it to run right with the stock ECU.
