Vtec Mini has problem, revin idle?
Old Sep 6, 2006 | 02:42 PM
Originally Posted by HatchVX
Like i said before just use brake cleaner and if there is a leak the rev will raise up.
Brake Cleaner? if it gets on the paint it'll eat through it if you don't wipe it off... WD-40 will work
Old Sep 6, 2006 | 05:11 PM
anthony12389's Avatar
anthony12389
i had the same problem with my b16, it was my brake booster.. if u wuld pull the pedal up with ur hand it wuld idle fine but as soon as u pressed the brake in it wuld star idle hopin again.. try pullin ur brake pedal up with ur hand an see if it stops.. sometimes u gotta mess with it a bit to stop.. if the brake pedal is the problem its the booster
Old Sep 6, 2006 | 07:27 PM
VTEC Mini's Avatar
VTEC Mini
thanks for all the info... its been rainin so i havent had a chance to look at it.. but tomorrow im on it.... Its OBD1... but now that you guys bring up the brake booster.. i did notice that im leakin a little fluid from in that area.. so im going to clean and tighten that up and see what happens..... and i blew up the factory motor mounts on sat doing a light-to-light 2dn to 3rd gear rhomp with a older viper... lol the guy looked shocked as all the rubber from my tires was landing on his head as i took off.... it was a fun time... anyways i got a set of HASport mounts... are those good? I hope so... i needed something quick and hopefully wont give as much as the factory ones.... anyways.. im going to check the booster tomorrow and let ya all know wasssup....
thanks all~
and i have a boring video on you tube of a stroll down the parkway.....
http://www.youtube.com/watch?v=C0zeZAynV-s
Old Sep 17, 2006 | 08:04 PM
VTEC Mini's Avatar
VTEC Mini
ok.... it was a vaccum leak!.... thanks for all the info!
