Help with b16 head!!!
Old Jun 29, 2006 | 08:15 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by mberndt
Reuse a head gasket??
Never heard of anyone actually reusing a head gasket. I had a problem where I put a new gasket on, ran the car for <5 miles, then removed the head again, and I still didn't reuse the old gasket.
I am going to be trying to reuse mine this weekend.
If you have gone through as many headgaskets as I have, you would probably attempt the same. I'll have to let you guys know how it went.
Old Jun 29, 2006 | 09:30 PM
dubcac's Avatar
dubcac
I
I reused a headgasket...but I never started the motor. o:
Old Jun 29, 2006 | 09:31 PM
pomansouth's Avatar
pomansouth
honda makes good gaskets, and as long as these gaskets are installed properly, they should be reusable if need be...it also is not a bad idea to put hondabond around all of the water ways and oil passages in-order to help seal everything...
Old Jun 29, 2006 | 09:41 PM
Provocateur
On permanent hiatus
They may be made well, but they are only meant to be clamped down once. If you see what happens to a thicker headgasket after torquing and removing it, you would see what I mean.
And honda-bond is a terrible idea on cylinder heads. It will not stand up to the heat of combustion and will cause some serious problems because it cannot be applied evenly and will cause leaks. If you are going to use a gasket, you should use a copper spray to acheive an even coat of gasket that will stand up to the temperatures present near the headgasket.
Old Jun 30, 2006 | 05:26 AM
pomansouth's Avatar
pomansouth
argue with endyn then, I know exactly what happens to a gasket once used, but I have used the same gasket for 3 different torquing sessions, I am now using it and no problems, cometic is the same way, as long as the motor hasnt been heated to operating temp, the gasket is still ok... endyn uses hondabond and they create pretty big numbers all motor so I use hondabond aswell, go to theoldone.com and check it out.....I dont like copper spray personally, it doesnt seem like a sealant to me but rather more of a lubricant:hsdunno:
