knock sensor - I need help!
Old May 24, 2006 | 03:01 PM
wwwbret's Avatar
wwwbret
Default knock sensor - I need help!
Hi all, great forum here! On my 98 gs-r, I replaced the knock sensor & still getting check engine light & knock code. How do I know if the wiring is bad or if the sensor is actually detecting knocking? I've listened to the engine & it certainly doesn't sound like it's knocking.
Living in NJ, have supercharger & hondata s200. Put stock computer & injectors back in, running no boost, back to OB2 for the good ole 2 year check. Have I/H/E on - could that be tripping the knock sensor or is wiring f-ed up? Got the car used & had to get a replacement stock ecu - got 37820-P72-A04 - is A04 vs A03 potentially the problem??
I'm losing my marbles w/ this for 3 weeks now. Please help! many thanks in advance!
Old May 24, 2006 | 03:04 PM
wwwbret's Avatar
wwwbret
ps - if it is the knock sensor tripping, how can I desensitize it or fool the ecu that it's working properly?
Old May 24, 2006 | 04:46 PM
mberndt's Avatar
mberndt
Don't know about the difference in A04 and A03, but the knock sensor produces an AC signal, that, when the amplitude is high enough - caused by vibration or knock, it will trip the computer...
It could be wiring, but I'm not sure...
Wrap it in duct tape and leave it hanging, LOL...
Do u have a supercharger? it could possibly be detonating...
Old May 26, 2006 | 02:00 AM
wwwbret's Avatar
wwwbret
thanks for the reply. Definitely no detonation in this setup as the supercharger is bypassed. Isn't there a way to ground out the sensor to fool the computer that knock sensor is working properly? I thought I saw something about that a while ago but can't find it. Maybe a could sponge & duct tape it & let it hang & plug the hole w/ the xtra sensor. Hmmm? Still would love to really get to the bottom if it! Anyone else have any ideas?
Old May 26, 2006 | 06:23 AM
civic401's Avatar
civic401
I had a problem with the knock sensor before and it turn out that the wire wasn't connected to the knock sensor. The wire was to far back and when I plug it in it wasn't really touching.. So what I did was, I push the plastic cover back and pull the wire forward and connect it together. Then once it was connected, I slowly push the plastic cover forward to cover the sensor.. So check to see if its really connected.
Old May 26, 2006 | 08:11 PM
wwwbret's Avatar
wwwbret
just to close this thread. problem finally resolved by rerunning wire as if I did an engine swap. thanks!
