which trannys are compatible with b16a?
Old May 20, 2006 | 09:23 PM
Grifter's Avatar
Grifter
Default which trannys are compatible with b16a?
also would it be worth it to get a new tranny instead of replacing synchros?
Old May 20, 2006 | 09:41 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Any B series tranny will work. I am assuming your current tranny is cable, so any cable B series tranny will bolt up. Any B series hydraulic tranny will bolt up to a hydraulic cable system.
Most of the times, a used tranny can be cheaper than a full overhaul. It wouldn't make sense to do all that work for just a synchro. If you can find a cheaper compatible tranny for a decent price, that would be a better choice than a full overhaul.
Old May 20, 2006 | 09:45 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Used or junkyard transmissions are a gamble at best IMO.
I went through 2 used transmissions on my GTi before giving in and rebuilding the stock unit. I would recommend a rebuild instead.
It may cost more, but the benefit of having warranteed work and guaranteed results are worth the added expense IMO. :shrug:
Old May 20, 2006 | 10:18 PM
Provocateur
On permanent hiatus
Very valid point.
I should have specified that I meant a private party sale like Honda-tech or a local ad where the seller knows that the tranny doesn't grind and has been taken care of.
In my case, if I were to sell my tranny to someone, I know that it doesn't grind at all and has been taken care of, so you wouldn't run the risk of getting another grinding tranny from a junkyard pull.
A rebuild would be the best option, but certainly won't be the cheapest.
Old May 31, 2006 | 06:06 PM
hitman619's Avatar
hitman619
SDSU Basketball
it's actually about the same price... the junk yard wanted $700.00 90 day warranty....
rebuild place wanted 750.00,
800.00 for type r limted slip (provided by me) 1 year warranty..
they're located in lemon grove ca
PM if you guys want the phone number or address
