turbo or supercharger?
Old May 31, 2006 | 06:03 PM
Chem Geek's Avatar
Chem Geek
H22A powered EH2!
...where the fack did you get that idea?
Uhm...I don't know?! :hsdunno:
Yea the turbo's make up for it quickly, and I don't know how it compares (quantitatively) to a SC as far as how much hp it takes to run, kinda hard to tell ya know. But I would assume turbo takes less as it's more efficient, but it's not free!
Thanks for the auto-x update, I appreciate the info.
Old May 31, 2006 | 06:58 PM
gsr wannabe's Avatar
gsr wannabe
Default Challenge...
^ actually, I bet it would be incredibly easy to find out for a common size...lets say:
1996-2000 b16 engine, JRSC, and a cost-wise equal garrett kit...stock except for the Forced induction...
We'll measure efficiency by final out put to the wheels in terms of HP & TQ...which ever form ( SC/turbo ) makes more on a stock engine...
I want to know whp, & wtq and boost pressure ( lbs )...I'll post up what I find w/links...LMK what you find...post back here by 10pm central with what you find...
By "free" HP, all that is meant is the source of energy used to run your preference of compressor...
-turbo uses what's already there...( Exhaust gas pulses )
-sc uses pulleys that detract from crank power...( to run rotors on JRSC )
Old May 31, 2006 | 07:40 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Straight from the book, Honda/Acura Engine Performance by Mike Kojima
Here is the long and boring nerd way to add some validity to the power debate. Let's figure out how much power it takes to compress the air to make some serious power. We will do this in two ways: we will figure the differences in intake air temp for a turbo, a Roots supercharger and a centrifugal supercharger. Then we will show how much power it takes to turn the supercharger.
First, let's calculate Delta T for the various compressors. Delta T is the change in the intake air temp after it is compressed.
Delta T = Intake Absolute Temperature x (Pressure Ratio to the .238 power -1)/ Compressor Efficiency
Let's assume our engine is going to run 20 psi of boost or a pressure ratio of 2.36.
Pressure ratio = boost pressure + 14.7/14.7
The temperature scale engineers use for absolute temperature is the Rankin Scale. On the Rankin Scale, zero degrees is absolute zero. So assuming our intake air temp is 85 degrees, lets call that 545 degrees Rankin.
Let's say our match car is a hot Acura GSR with a B18C motor. By using the compressor matching equations...we figure that the B18C can flow about 45.3 lbs/min going full tilt at 20 psi.
So here we go. Let's figure out Delta T for our good turbo first. Let's assume an efficiency of 78%, as there are many turbos that can do that at the given flow and pressure ratio.
Delta T = 545 x (2.36 to the .238 power -1)/0.78
Delta T = 158 degrees
A 4-cylinder sized centrifugal supercharger is probably much less than 70% efficient at this point but let's be kind to it and assume that plugging and chugging gets us a temp of 177 degrees.
Now there are not any current Roots blowers on the market that can support this sort of boost pressure on a small 4-cylinder car but let's suppose there is and let's be very kind, assuming it will get 60% compressor efficiency at 20 psi and 45.3 lbs/min of flow...Plug and chug and we get a Delta T of 206 degrees.
Now Delta T is the difference in temperature after being compressed. What would our intake temp be for the Roots assuming an intake temp of 85 degrees?
85+206 = an egg frying 291 degrees with no intercooler!
Now let's figure out the power required to make the boost from these three compressors. The equation for the power needed is:
Power in BTU per minute = Mass Flow x Cp (a coefficient) x Delta T/Compressor Efficiency
To convert BTU per minute to horsepower divide by 42.4.
Power = 45.3 x .242 x 158/78 = 2220 BTU min/42.4 = 52 hp recovered from the exhaust.
So here is the horsepower that won't be taken from the crankshaft but recovered from the exhaust stream by the turbocharger on our GSR.
If you check out the gas power cycle in a thermodynamics book, you need to correct the power equation a little for a supercharger. Since a supercharger adds pressure to one side of the motor and the turbo adds it to both, we need to do an estimation of the power recovered by the supercharger on the intake stroke. The equation is:
(Boost Pressure x Engine Displacement in cubic inches x RPM)/2)/12 x 60 x 550
So for our B18C:
(20psi x 110 x 8500 rpm/2)/396000 = 24 hp
To figure out how much power the centrifugal supercharger takes from the crankshaft, let's plug and chug again, getting a 65 horsepower, subtract 24 hp and you get a crankshaft power loss of 41 hp.
Repeating for the Roots blower gets us a loss of 65 horsepower stolen from the crank.
So simply reducing our meager data, if you calculate the potential hp of our turbocharged B18C, we will get about 453 hp. This might be around 412 hp from our centrifugally supercharged version of the same motor and 388 hp from our Roots equipped motor.
Now this example has been vastly oversimplified and does not take into account differences in volumetric efficiency, air density differences for intercooler effectiveness or lack thereof, dynamic matching to compressor maps and engine tuning variables that have to be different between the types of compressors. Of these variables, all of them except for VE differences would be in favor of the turbo. This shows that all other things being equal, the turbocharger does have an advantage when it comes to sheer power output. The compressor efficiencies we used for the superchargers were very conservative. In real life the superchargers would probably be much worse at 20 psi. If we upped the boost higher, to higher pressure ratios where turbochargers really shine, the calculated differences would be even greater.
Old May 31, 2006 | 08:01 PM
sunnyrodeo's Avatar
sunnyrodeo
its personal preferance than anything else.. supercharger makes more usable pwer at lower rmp but turbo makes more peak power at higher rpm. for race course supercharger would be better casue u will be slowing down and going and stuff but for drag racing turbo would be better. personally i would go with turbo. nothign like turbo whine and BOV
Old May 31, 2006 | 09:18 PM
flooredfab's Avatar
flooredfab
www.flooredfab.com
Just for sake of beating this some more. I'm curious....What about top fuel dragsters running.... OH lets say 5000+ HP "SUPERCHARGED"? Hows a supercharger making less hp at the top end? Theres alot of missconception on forced induction these days. Propper choice of componets per application will yield the best results period. If you choose a turbo with a .80 turbine a stick it on a 1.5ltr...Ya its going to have ONLY top end power or if you put a shelf stock blower on an engine size it was never designed for and used it for space constraints, then yes you'll lose top end power. Forced induction can be benificial on all ends of the spectrum whether its belt driven or gas driven. It all rely's and a balance of propper part selection and tunning.
Old Jun 1, 2006 | 04:10 AM
Chem Geek's Avatar
Chem Geek
H22A powered EH2!
And it's Däs Schmoo with the über-geek technical throw down for the win! :yay:
I agree flooredfab, all in the setup.
Old Jun 1, 2006 | 09:51 AM
Provocateur
On permanent hiatus
It is just a bit of overly simplified math, but it shows that superchargers are not a good choice on a small 4 cylinder motor when all out power without parasitic power loss is desired....and we are talking about small 4 cylinder Honda motors.
Don't get me wrong...for a small power goal for a daily driver, a supercharger is a decent choice. Too bad the only offering for a roots blower on a Honda is junk.
Old Jun 1, 2006 | 08:05 PM
gsr wannabe
Thanks for the technicals, schmoo...
Old Jun 2, 2006 | 03:49 AM
schmi220's Avatar
schmi220
Large Member
I read an amazing article in Motor Trend last year about these cars. There is a 900hp parasitic loss at the crank just to run the supercharger. I think it also said the reason they don't run turbo is because the exhaust is just too hot coming out. The ignition temp for the fuel is insane. I'll try to find the article.
Old Jun 2, 2006 | 09:23 PM
daveb91's Avatar
daveb91
Boo Boo Kitty F*#k
Originally Posted by daveb91
yes the SC "uses" Hp to make hp but when I am driving with the bypass valve open I do not notice it at all. Probably uses less power to drive than a AC system.
It doesnt use much HP I get basically the same MPG as long as I keep my foot out of it.
