Engine swap question??? Help
Old Feb 23, 2006 | 07:58 AM
BlkAkonda's Avatar
BlkAkonda
!!**Guess I'm saving for a new whip!**!!
Old Mar 6, 2006 | 02:15 PM
np63om's Avatar
np63om
Originally Posted by sherwood
the swap is pretty easy and striaght forward, just search this site alone and you'll find ten, 20, 30 threads explaining what you're asking.
http://www.sportcompactcarweb.com/tech/0311scc_hybrid/ will show you the process and how to goes for the most part, the only difference being they used a hasport kit that was never put into production (because of the ease of install with stock motor mounts there really wasnt much there to do) i believe you use all but one of the stock mounts, the otherone just needs to be machined from one of the remaining mounts to fit.
for the engine almost everybody on here will suggest www.hmotorsonline.com their engines are in grade A condition and they come to you performing and looking good. you would be looking for the h22a swap....
if the car you have is a manual 5 sp. you are all set, if it is automatic i'd have to tell you to sell it and buy a manual as it will be easier and alot less hassle, it will cost less in the long run aswell.
GOOD SITE, by the way can i swap the engine 1.4is civic of 95 5Doors to 1.8 VTI vtec, can i do that, the first one don´t VTEC sensor, the second have, can i swap, do you know site to help me out with this. One more time: nice site
Thank you all.
Old Mar 8, 2006 | 07:13 AM
AcuraFanatic's Avatar
AcuraFanatic
No. No, no no. Automatic to manual swaps are a sinch in Honda's. All the transmission mounts for a manual are preinstalled on automatics. Automatic Hondas are predrilled for a clutch pedal. You can do a conversion for probably less than $400 worth of parts if you already have a manual transmission coming with the car.
I did an automatic to manual conversion on my buddy's '89 CRX. Cost him $550, I got it done in two days.
No reason whatsoever to sell the car.
Old Mar 8, 2006 | 07:15 AM
AcuraFanatic
Originally Posted by 94projectvtec
Thanks for the advice, the web pages you gave should be really helpfull. Also is this the best swap that there is for this car. I want to get the most hp possible. I just wanted to make sure that this is the engine to do the job. Also it is an auto, for now.
If you have the budget, you might also want to consider swapping in a K24A2. HASport makes mount kits now for the 5th gen Accords. K-Series has a ton of potential when compared to the H22 (and B-Series for that matter).
