90 integra won't start??????????????????HELP!!!
Old Feb 4, 2006 | 04:31 PM
KIllateg's Avatar
KIllateg
Default 90 integra won't start??????????????????HELP!!!
ya i got a 90 integra rs B18a is cruisin about 120kph the the car just stalled out then i tryed restarting it and it started but when i pressed on the gas it just seemed to bog and died out now it wont start and its got a popping sound coming out of the exhaust but wont start. Its got new plugs, timing belt, cap, rotor and still it wont start any info would be great.
Old Feb 4, 2006 | 05:45 PM
dapump2003's Avatar
dapump2003
you should check your fuel system...
Old Feb 4, 2006 | 06:13 PM
teg92's Avatar
teg92
WHAT OK YEAH!
ya check your fuel pump, try changing the fuel filter and if both are good check your main relay
Old Feb 4, 2006 | 09:08 PM
KarrNtegGSR's Avatar
KarrNtegGSR
Default Call this number order a electrical trouble shooting manuel.
Call this number order a electrical trouble shooting manuel. 1800-782-4356
Old Feb 4, 2006 | 11:40 PM
wildcarditr102's Avatar
wildcarditr102
My new toy
lol, don't buy a book
I had a similar problem in my Jeep a little bit ago. When you say it won't start, does it crank, but just not fire up, or is there no cranking at all?
Old Feb 5, 2006 | 07:08 AM
KIllateg's Avatar
KIllateg
its cranks but won't fire and its gettin gas i think cause its smells flooded or could the main fuel relay be bad still
Old Feb 6, 2006 | 03:36 AM
wildcarditr102
My new toy
If you're sure fuel is being delivered I would say it's an ignition problem. I had the same shit when my battery was dying while driving (lack of sufficient ignition the same). I don't know a lot about what happened, but I figured the popping was from an unburned mixture of fuel/air that escaped the cylinder (from incomplete combustion due to weak ignition) igniting in the exhaust from the heat.
I think that might be happening with you. Somehow your fuel is not being properly burned. I could be wrong, someone correct me if I am...
While cranking, does it tend to sputter and die, or is there no give at all?
Did you replace the distributor cap or the capacitor/coil?
Old Feb 7, 2006 | 10:54 AM
Sharpe's Avatar
Sharpe
check that the rotor is pointing in the right direction when the no 1 piston is at top dead center. my car did this and it turned out the screw came off of the rotor and the rotor spun, so i would crank the car and all i got was wirr wirr wirr pop! pop!
