Lightened Flywheel
Old Oct 17, 2005 | 09:30 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by B16a2VTIguy
So does any1 know if you lose torque with a lightened flywheel??
I'm probably gonna go N/A so is the a ideal weight i should go for??
I was thinking of a fidanza one, anyone heard anything good or bad about them??
You don't lose torque. If anything, it is improved because it is more efficiently being placed on the ground.
7.5-9 lbs is ideal for the best acceleration, but you will run into stalling issues if you have an erratic idle like that on a turbo setup or aggressive cam profile setup. Fidanza is a good choice, but a little too light for my taste. I like the ACT Prolite.
Old Oct 17, 2005 | 09:57 AM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
Sound, coz ive only got 120ftlb of torque at the mo and dont wana loose any of it!! Do u think the fidanza flywheel would be ok with stage 2 cams (kent cams, similar to skunk2's profile i think)??? I want a good idle.
Thanks 4 da help
Old Oct 17, 2005 | 10:34 AM
psx_pat's Avatar
psx_pat
Well, if you lighten the flywheel,sure you get faster throttle response. But if the city where you live have a lot of uphill I suggest not to lighten the flywheel cause with lighten flywheel, you loose the momentum just like mean azz acura said.
Old Oct 17, 2005 | 10:46 AM
Provocateur
On permanent hiatus
That really isn't true. Taking off on a hill is a little difficult, but you will have more horsepower going to the wheels to get you up the hill once you start moving.
Old Oct 18, 2005 | 05:13 AM
B16a2VTIguy
Built B16a
When u say taking off on a hill will be a little more difficult, do you mean it will just want to stall easier?? And i presume if you just keep the revvs a little higher and not let the revs die as u let the clutch out all will be good?
Thanks agen
Old Oct 18, 2005 | 10:30 AM
Provocateur
On permanent hiatus
Thanks agen
Yeah, you have to give it a little more gas than normal to get it moving.
Old Oct 19, 2005 | 03:21 AM
B16a2VTIguy
Built B16a
Sound, another mod to get ordered! thanx 4 all help!
