check enging light....distributor??
Old Sep 8, 2002 | 10:08 AM
midwestgsr's Avatar
midwestgsr
Default check enging light....distributor??
i got in my 97 gsr one night and turned it on and the check engine light came on. i took my car to a friends house, we checked to see which code it was and it was a code 8. we disconnected the batt and reconnected it and the check engine light stayed off. we came to the conclusion that it was a sensor in the distributor, just a misread. however, later i was driving in the country and at a 6500rpm 3rd gear shift it came back on.
any ideas?
if it is the distributor does anyone know where i can get a replacememnt???
thanks
Old Sep 8, 2002 | 11:06 AM
kinghawk's Avatar
kinghawk
Its the signal coming from one of the internal components in the distributor....Crankshaft position sensor/TDC sensor disconnected or interuption, TDC no signal.... What I would do is check the TDC coil (inside the distributor and see if you get continuty..... These parts can be replaced ( not sure if you can purchase them from the store) but it would take some soldering work. But you can repair the distributor you got.... no need to get a replacement unless the bearings go out or something
Code 8 would be either of these parts in part by part failure, loose/bad wiring or a misreading from the ECU at times......
Old Oct 5, 2002 | 05:35 PM
PnX-R's Avatar
PnX-R
Finally.. Sheesh, you know how hard it is to find someone that actually know something about electrical and ignition.. Listen to this guy, he knows what he's talking about.. :thumbup:
Old Jul 17, 2003 | 11:09 PM
ek97hatch's Avatar
ek97hatch
hmmm.. i'm having the same problem. i got the code # 4 though, which is the crankshaft position sensor. It's keeping me from reving my engine pass 3500. I was going to buy a used distributor but if the sensor can be swapped out, i might have someone do it for me.
hachacker5024
Engine Swaps, Tech & Tuning
Jul 7, 2007 06:52 AM
tay12186
Dec 13, 2006 09:47 AM
Dthreat619
Sep 16, 2005 06:09 AM
Sick Wit It
9
Feb 20, 2004 03:41 PM
max_power
5
May 29, 2003 11:08 AM
