does anyone have an LS vtec - turbo?
Old Aug 30, 2002 | 07:19 PM
antennas up's Avatar
antennas up
Banned
Default does anyone have an LS vtec - turbo?
or is this not a good idea?
Old Aug 30, 2002 | 09:13 PM
ur31337's Avatar
ur31337
Colby
Built right it'd be fine, but done sloppy, you're just asking for trouble.
Old Aug 30, 2002 | 09:45 PM
qtiger's Avatar
qtiger
Might get more power by just sticking with LS turbo and putting the extra $ into building the LS.
Old Sep 2, 2002 | 06:48 AM
....zZzZzZzZzZz's Avatar
....zZzZzZzZzZz
Id rather have GSR turbo just for the fact that no matter what LS/vtec will leak oil and with turbo u dont want that. Gsr's have a good rep too, how many honda's do u know that use a GSR run 9's? they are strong motors. The LS is a strong motor too, probably can run 10psi on stock internals and maybe some Dsm injectors or other bigger injectors. My friend ran 12.7 in his Si hatch with a stock Ls turbo on 7psi.
Old Sep 4, 2002 | 10:26 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
Default What's up?
That's my suggestion right there. With a turbo setup, all the power you want is just a crank of the boost controller away. You'd be better off spending the $1000 for the VTEC head and everything else on a good set of pistons and rods for the LS motor. Just my opinion.
LS/VTEC's don't nessicarly leak oil, assuming all the connections are done correctly and solidly. Problem with most LS/VTEC is there not done correctly or solidly. Seeya.
Old Sep 7, 2002 | 08:20 PM
redheat86's Avatar
redheat86
DoriTen y0
-that statement is quite wrong.. i dont see where you get all ls/vtecs or crvtecs leak oil?
-the reason they leak is because someone was half ass on the oil lines. my roomate runs a built b20 vtec and it has ran atleast 10k miles and for 6 months problem free with constant 8500 redlines. also one more thing have you had direct personal experiance with the lsvtecs that were leaking oil or is it just from gets said on forums?
Old Sep 8, 2002 | 07:31 AM
nutsack's Avatar
nutsack
Giant Member
without turbo you wouldn't want it leaking oil too.
Old Sep 12, 2002 | 08:57 AM
delsol2001's Avatar
delsol2001
hustlin member
they also make ls/b20/vtec head gaskets so no oil leaks there either!
Old Sep 26, 2002 | 02:57 PM
APG-LsVtec's Avatar
APG-LsVtec
a friend of mine has the ls/vtec turbo in his civic si. .the car is mean .. i'll ave to find out the hp he is pushin
b00gers
Nov 26, 2005 08:37 PM
TurboRSXS
RSX & 02-05 Civic Si
8
Oct 9, 2005 08:04 PM
Fire
CRX & Pre 92 Civic
5
Jun 20, 2005 09:09 AM
Mike__
Accord
Feb 1, 2005 04:35 PM
mizturyous
Accord
25
Feb 20, 2004 05:06 PM
